Help Center/ Direct Connect/ User Guide/ Virtual Gateways/ Modifying a Virtual Gateway
Updated on 2025-11-12 GMT+08:00
After creating a virtual gateway, you can modify its settings.
  1. Go to the Virtual Gateways page.
  2. In the upper left corner of the page, click and select a region and project.
  3. Locate the virtual gateway you want to modify and click Modify in the Operation column.
  4. Modify the name, local subnet, and description, and then click OK.
    Figure 1 Modifying a virtual gateway
