Help Center/ Direct Connect/ User Guide/ Connections/ Creating a Connection
Updated on 2026-06-16 GMT+08:00
Standard Connection
Standard connections provide self-service connections and full-service connections for you to choose as required.
  • Self-service connection: Huawei Cloud only provides the port. You need to create a connection on the console, and lease a line from a carrier.
  • Full-service connection: You only need to create a connection on the console, and Huawei Cloud will complete all operations required for network connectivity.
Figure 1 shows an example of how standard connections work.
Figure 1 Accessing the cloud using standard connections
  1. Go to the Connections page.
  2. In the upper left corner of the page, click and select a region and project.
  3. In the upper right corner, click Create Connection.
  4. On the Create Connection page, enter the equipment room details and select the Huawei Cloud location and port based on Table 1.
    Figure 2 Creating a self-service connection
    Table 1 Parameters for creating a connection
    Example Value
    Billing Mode
    Specifies how you will be billed for the connection. Currently, only Yearly/Monthly is supported.
    Yearly/Monthly
    Region
    Specifies the region where the connection will be deployed. You can also change the region in the upper left corner of the console.
    CN-Hong Kong
    Connection Name
    Specifies the name of the connection.
    dc-123
    Huawei Cloud Location
    Specifies the Direct Connect location where your leased line can be connected to.
    HK-Sai Kung-Mobile
    Carrier
    Specifies the carrier that provides the leased line.
    Other
    Port Type
    Specifies the type of the port for leased line access. You can select 1GE single-mode optical port, 10GE single-mode optical port, 40GE single-mode optical port, or 100GE single-mode optical port.
    Leased Line Bandwidth (Mbit/s)
    Specifies the bandwidth of the leased line. This is the bandwidth of the leased line you purchase from the carrier.
    100 Mbit/s
    Equipment Room Address
    Specifies the address of your equipment room. The address must be specific to the floor your equipment room is on.
    Room xx, xx building, xx road, xx district, xx city
    Tag
    Adds tags to help you identify your connection. You can change them after the connection is created.
    example_key1
    example_value1
    Provides supplementary information about the connection.
    Required Duration
    Specifies how long the connection will be used for.
    3 months
    Auto-renew
    Specifies whether to automatically renew the subscription to ensure service continuity.
    For example, if you select this option and the required duration is three months, the system automatically renews the subscription for another three months.
    3 months
    Enterprise Project
    Specifies the enterprise project by which connections are centrally managed. Select an existing enterprise project.
    default
  5. Click Confirm Configuration.
  6. Confirm the configuration and click Submit.
    Then confirm the requirements with the Direct Connect manager.
    If your request is not approved, repeat 3 to 6 based on the review comments and submit the request again.
  7. Contact the carrier for cabling after your request is approved.
    After the cabling is complete, locate the connection in the connection list and click Confirm Cabling in the Operation column.
    Figure 3 Confirm cabling
  8. In the displayed dialog box, click OK.
  9. In the connection list, locate the connection and click Confirm Configuration in the Operation column.
  10. Confirm the configuration and click Pay Now.
  11. Confirm the order, select a payment method, and click Confirm.
  12. Wait for Huawei Cloud to complete the construction.
    Huawei onsite engineers will connect the leased line to the port on the Huawei Cloud gateway based on the customer's information within two working days.
  13. Verify that the connection is in the Normal state, which means that the connection is ready, and the billing starts.
  4. Click Full Service Installation.
  5. Provide information about your equipment room and select a Huawei Cloud location. For details about the parameters, see Table 2.
    Figure 4 Creating a full-service connection
    Table 2 Parameters for creating a connection
    Example Value
    Available Carriers
    Specifies the carriers that are allowed to enter your equipment room.
    Other
    Port Type
    Specifies the type of port on the device in your equipment room for connecting to the leased line.
    Region
    CN-Hong Kong
    HK-Sai Kung-Mobile
    Port Type
    Connection Name
    Specifies the name of your connection.
    dc-123
    Billing Mode
    Yearly/Monthly
    1,000 Mbit/s
    Required Duration
    1 year
    Tag
    example_key1
    example_value1
    Enterprise Project
    default
    Contact Person/Phone Number/Email
    Specifies the contact information about the person who is responsible for your connection.
    Tom
    +86 139xxxxxxxx
    Tom@mail.com
  6. Click Submit.
  1. Wait for Huawei Cloud to complete the site survey.
    Huawei Cloud site survey usually takes three working days. Huawei Cloud evaluates your requirements and the carrier's resources and confirms whether your requirements can be met. If your requirements can be met, Huawei Cloud will place an order for you.
  2. Confirm and pay for the order.
    1. In the connection list, locate the connection and click Confirm Configuration in the Operation column.
    2. Confirm the connection configuration and expenses, and then click Next.
      You need to read and agree to the Full-Service Installation Statement before paying for the order.
    3. On the purchase page, select a payment mode and click Pay.
      If you select Download Contract, download a contract on the contract page and complete the payment. Discounts, if any, will automatically apply.
  3. Wait for Huawei Cloud to complete the following work:
    1. Contacts the carrier to deploy the leased line.
    2. Connects your on-premises data center to the cloud using the leased line.
    3. Contacts the carrier to complete in-building cabling.
      This step is required when you choose a full-service connection with a dedicated port and need cabling for your site.
    4. Enables the port.
  4. Confirm that you want to enable Direct Connect.
    1. In the connection list, locate the connection and click Confirm Completion in the Operation column.
    2. Click OK. Confirm that your connection is available for use, and the billing starts.
Partner Connections
Only certified Huawei Cloud partners can create partner connections, including operations connections and hosted connections.
  3. In the upper right corner, click Create Operations Connection.
  4. Specify the required parameters and click Confirm Configuration.
  5. Confirm the configuration and click Submit.
  6. Contact the carrier for cabling after your request is approved.
  7. In the displayed dialog box, click OK.
  8. In the connection list, locate the connection and click Confirm Configuration in the Operation column.
  9. Confirm the configuration and click Pay Now.
  10. Confirm the order, select a payment method, and click Confirm.
  11. Wait for Huawei Cloud to complete the construction.
  12. Verify that the connection is in the Normal state, which means that the connection is ready, and the billing starts.
  3. In the upper right corner, click Create Hosted Connection.
  4. Configure the parameters and click OK.
Helpful Links
