Unsubscribing from a Connection
Unsubscribing from a Self-Service Connection
If you do not need to use a self-service connection any longer, you can unsubscribe from it.
You can only unsubscribe from connections that are in the Normal state. If a connection is being created, you can unsubscribe from it after the connection is created.
- Go to the Connections page.
- In the upper left corner of the page, click
and select a region and project.
- Locate the connection that you want to unsubscribe from and click Unsubscribe in the Operation column.
- Locate the target connection and click Unsubscribe from Resource in the Operation column.
- On the Unsubscribe page, select the reason for unsubscription, confirm the refund amount, and select I understand a handling fee will be charged for this unsubscription.
- Click Confirm.
Unsubscribing from a Full-Service Connection
If you do not need to use a full-service connection any longer, you can unsubscribe from it.
For details, see Unsubscriptions.
