Updated on 2025-11-07 GMT+08:00
Modifying a Connection
After creating a connection, you can modify its name, bandwidth, equipment room address, and description.
- In the upper left corner of the page, click
and select a region and project. - Locate the connection you want to modify and click Modify in the Operation column.
- Modify the connection and click OK.
- Go to the Connections page.
Parent topic: Connections
