Help Center/ DataArts Studio/ User Guide/ DataArts Migration (Real-Time Jobs)/ Job Performance Optimization/ Optimizing the Parameters of a Job for Migrating Data from SQL Server to GaussDB(DWS)
Updated on 2025-09-09 GMT+08:00
Optimizing Source Parameters
Optimization of data extraction from SQL Server
No optimization configuration items are available.
Optimizing Destination Parameters
Optimization of data writing to DWS
You can modify writing parameters in the DWS destination configuration or click View and Edit in the advanced configuration to add advanced attributes.
Figure 1 Adding advanced attributes
Table 1 Parameters for optimizing DWS writing
Type
Default Value
Write Mode
enum
UPSERT
Mode for writing data to DWS, which can be set in the destination configuration. COPY MODE is recommended for real-time migration jobs.
  • UPSERT: batch update
  • COPY: DWS-dedicated high-performance batch import
Maximum Data Volume for Batch Write
int
50000
Maximum number of data records that can be written to DWS at a time. You can set this parameter in the destination configuration.
If Maximum Data Volume for Batch Write or Scheduled Batch Write Interval is met, data will be written.
Increasing the number of data records written at a time can reduce the number of DWS requests but may increase the duration of a single request and the amount of cached data, which affects memory usage. Adjust the value based on the DWS specifications and load.
int
3
Interval for writing data to DWS. You can set this parameter in the destination configuration.
If the interval is reached, cached data will be written.
Increasing the value of this parameter increases the number of data records cached in a single write, but it takes a longer time for DWS data to become visible.
sink.buffer-flush.max-size
int
512
Amount of the data that can be written to DWS at a time. The default value is 512 MB. You can set this parameter in the advanced settings of the destination configuration.
If the size of cached data reaches the upper limit, data will be written.
Similar to Maximum Data Volume for Batch Write, increasing the amount of data written at a time can reduce the number of DWS requests but may increase the duration of a single request and the amount of cached data, which affects memory usage. Adjust the value based on the DWS specifications and load.
