Optimizing the Parameters of a Job for Migrating Data from MySQL to DMS for Kafka
Optimizing Source Parameters
Optimization of data extraction from MySQL
You can click Add Custom Attribute in the Configure Task area and add MySQL synchronization parameters.
The following tuning parameters are available.
| Parameter | Type | Default Value | Description |
| scan.incremental.snapshot.backfill.skip | boolean | true | Whether to skip reading Binlog data. The default value is true. Skipping reading Binlog data can effectively reduce memory usage. Note that skipping reading Binlog data provides only at-least-once guarantee. |
| scan.incremental.snapshot.chunk.size | int | 50000 | Shard size, which determines the maximum number of data records in a single shard and the number of shards in the full migration phase. The larger the shard size, the more data records in a single shard, and the smaller the number of shards. If a table has a large number of records, the job will divide the table into shards, which occupy too much memory. To avoid this issue, adjust the value of this parameter based on the number of records in the table. If scan.incremental.snapshot.backfill.skip is false, the real-time processing migration job caches data of a single shard. In this case, a larger shard occupies more memory, causing memory overflow. To avoid this issue, reduce the shard size. |
| scan.snapshot.fetch.size | int | 1024 | Maximum number of data records that can be extracted from the MySQL database in a single request during full data extraction. Increasing the number of requests can reduce the number of requests to the MySQL database and improve performance. |
| debezium.max.queue.size | int | 8192 | Number of data cache queues. The default value is 8192. If the size of a single data record in the source table is too large (for example, 1 MB), memory overflow occurs when too much data is cached. You can reduce the value. |
| debezium.max.queue.size.in.bytes | int | 0 | Size of the data cache queue. The default value is 0, indicating that the cache queue is calculated based on the number of data records instead of the data size. If debezium.max.queue.size cannot effectively limit memory usage, you can explicitly set this parameter to limit the size of cached data. |
| jdbc.properties.socketTimeout | int | 300000 | Timeout interval of the socket for connecting to the MySQL database in the full migration phase. The default value is 5 minutes. If the MySQL database is overloaded, and the SocketTimeout exception occurs for a job, you can increase the value of this parameter. |
| jdbc.properties.connectTimeout | int | 60000 | Timeout interval of the connection to the MySQL database in the full migration phase. The default value is 1 minute. If the MySQL database is overloaded, and the ConnectTimeout exception occurs for a job, you can increase the value of this parameter. |
Optimizing Destination Parameters
Optimization of data writing to Kafka
Generally, data is written to Kafka fast. If the speed is slow, increase the concurrency.
