Help Center/ DataArts Studio/ User Guide/ DataArts Migration (Real-Time Jobs)/ Job Performance Optimization/ Optimizing the Parameters of a Job for Migrating Data from MySQL to DWS
Updated on 2025-09-09 GMT+08:00
Optimizing Source Parameters
Optimization of data extraction from MySQL
You can click Add Custom Attribute in the Configure Task area and add MySQL synchronization parameters.
Figure 1 Adding custom attributes
The following tuning parameters are available.
Table 1 Tuning parameters for full data synchronization
Type
Default Value
scan.incremental.snapshot.backfill.skip
boolean
true
Whether to skip reading Binlog data. The default value is true. Skipping reading Binlog data can effectively reduce memory usage. Note that skipping reading Binlog data provides only at-least-once guarantee.
scan.incremental.snapshot.chunk.size
int
50000
Shard size, which determines the maximum number of data records in a single shard and the number of shards in the full migration phase. The larger the shard size, the more data records in a single shard, and the smaller the number of shards.
If a table has a large number of records, the job will divide the table into shards, which occupy too much memory. To avoid this issue, adjust the value of this parameter based on the number of records in the table.
If scan.incremental.snapshot.backfill.skip is false, the real-time processing migration job caches data of a single shard. In this case, a larger shard occupies more memory, causing memory overflow. To avoid this issue, reduce the shard size.
scan.snapshot.fetch.size
int
1024
Maximum number of data records that can be extracted from the MySQL database in a single request during full data extraction. Increasing the number of requests can reduce the number of requests to the MySQL database and improve performance.
debezium.max.queue.size
int
8192
Number of data cache queues. The default value is 8192. If the size of a single data record in the source table is too large (for example, 1 MB), memory overflow occurs when too much data is cached. You can reduce the value.
debezium.max.queue.size.in.bytes
int
0
Size of the data cache queue. The default value is 0, indicating that the cache queue is calculated based on the number of data records instead of the data size. If debezium.max.queue.size cannot effectively limit memory usage, you can explicitly set this parameter to limit the size of cached data.
jdbc.properties.socketTimeout
int
300000
Timeout interval of the socket for connecting to the MySQL database in the full migration phase. The default value is 5 minutes. If the MySQL database is overloaded, and the SocketTimeout exception occurs for a job, you can increase the value of this parameter.
jdbc.properties.connectTimeout
int
60000
Timeout interval of the connection to the MySQL database in the full migration phase. The default value is 1 minute. If the MySQL database is overloaded, and the ConnectTimeout exception occurs for a job, you can increase the value of this parameter.
Table 2 Tuning parameters for incremental data synchronization
Type
Default Value
int
8192
int
0
Optimizing Destination Parameters
Optimization of data writing to DWS
You can modify writing parameters in the DWS destination configuration or click View and Edit in the advanced configuration to add advanced attributes.
Figure 2 Adding advanced attributes
Table 3 Parameters for optimizing DWS writing
Type
Default Value
Write Mode
enum
UPSERT
Mode for writing data to DWS, which can be set in the destination configuration. COPY MODE is recommended for real-time migration jobs.
  • UPSERT: batch update
  • COPY: DWS-dedicated high-performance batch import
Maximum Data Volume for Batch Write
int
50000
Maximum number of data records that can be written to DWS at a time. You can set this parameter in the destination configuration.
If Maximum Data Volume for Batch Write or Scheduled Batch Write Interval is met, data will be written.
Increasing the number of data records written at a time can reduce the number of DWS requests but may increase the duration of a single request and the amount of cached data, which affects memory usage. Adjust the value based on the DWS specifications and load.
int
3
Interval for writing data to DWS. You can set this parameter in the destination configuration.
If the interval is reached, cached data will be written.
Increasing the value of this parameter increases the number of data records cached in a single write, but it takes a longer time for DWS data to become visible.
sink.buffer-flush.max-size
int
512
Amount of the data that can be written to DWS at a time. The default value is 512 MB. You can set this parameter in the advanced settings of the destination configuration.
If the size of cached data reaches the upper limit, data will be written.
Similar to Maximum Data Volume for Batch Write, increasing the amount of data written at a time can reduce the number of DWS requests but may increase the duration of a single request and the amount of cached data, which affects memory usage. Adjust the value based on the DWS specifications and load.
