Mapping Between PostgreSQL and MRS Hudi Field Types
DataArts Migration converts the source field type to the destination field type based on the default rule, and creates tables and synchronizes data in real time.
Field Type Mapping Rules
The following table lists the field types supported by a job that migrates data from PostgreSQL to Hudi.
Type |
PostgreSQL Data Type |
Hudi Data Type |
Description |
String |
CHAR(M) |
STRING |
Fixed-length string, filled with spaces |
VARCHAR(M) |
STRING |
Variable-length string with an upper limit of length |
TEXT |
STRING |
Variable-length string with no upper limit of length, similar to VARCHAR without length declaration |
Value |
BOOLEAN |
BOOLEAN |
Logical Boolean value (true/false) |
SMALLINT |
INT |
int2 |
INTEGER |
INT |
int/int4 |
BIGINT |
BIGINT |
int8 |
DECIMAL(M,D) |
DECIMAL(M,D) |
Accurate number with precision |
NUMERIC(M,D) |
DECIMAL(M,D) |
Equivalent to NUMERIC |
REAL |
FLOAT |
Single-precision floating point number (4 bytes) |
DOUBLE |
DOUBLE |
Double-precision floating point number (8 bytes). It can also be represented by FLOAT without precision. |
Date and time |
DATE |
DATE |
Date (1970-01-01) |
TIME(M) |
STRING |
Time of a day (08:00:00) |
TIMESTAMP(M) |
TIMESTAMP |
Date and time without the time zone (1970-01-01 00:00:00) |
TIMESTAMP(M) WITH TIME ZONE |
TIMESTAMP |
Date and time with the time zone (1970-01-01 00:00:00). It is TIMESTAMPTZ. |
Binary |
BYTEA |
Not supported |
Binary data ("byte array") |
