ModelArts Train
Function
You can orchestrate ModelArts Train operators to schedule the ModelArts workflow in DataArts Studio.
Parameters
Table 1 and Table 2 describe the parameters of the ModelArts Train node.
| Parameter | Mandatory | Description |
| ModelArts Workspace | Yes | ModelArts workspace. The workspace must be in the same region as DataArts Studio. |
| Workflow Version | Yes | ModelArts workflow version
| ModelArts Workflow | Yes | ModelArts workflow. The workflow must be in the same region as DataArts Studio. |
| Node Name | Yes | Name of the node. The value must consist of 1 to 128 characters and contain only letters, digits, and the following special characters: _-/<>. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed. Possible values:
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select this option, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
