Help Center/ DataArts Studio/ User Guide/ Buying and Configuring a DataArts Studio Instance/ Managing DataArts Studio Resources
Updated on 2025-11-18 GMT+08:00
You can centrally manage DataArts Studio resources.
Offline Resource Management
You can view all CDM clusters in a DataArts Studio instance and associate workspaces with CDM clusters.
A CDM cluster is available in a workspace only after they are associated with each other.
- Log in to the DataArts Studio console as user DAYU Administrator or Tenant Administrator. For details, see DataArts Studio.
- Locate an instance and click Access. Then click the Resources tab.
- On the Offline Resources tab page, view all CDM clusters in the instance, such as their statuses, private IP addresses, and public IP addresses.
- Click
in the Name column to expand the cluster details, such as the AZ, VPC, subnet, security group, specifications, cluster ID, and associated workspaces. Figure 1 Viewing cluster details
- Locate a CDM cluster and click Associate with Workspace in the Operation column. In the displayed dialog box, select or deselect workspaces and click OK to associate the CDM cluster with the selected workspaces. The CDM cluster is only available in the associated workspaces.Figure 2 Associating a CDM cluster with workspaces
