Updated on 2026-09-14 GMT+08:00
Auto Table Creation
CDM converts the field type of the source to the field type of the destination based on the default rule and creates a table at the destination.
Field Mapping in Automatic Table Creation
Figure 1 describes the field mapping between the DWS tables created by CDM and source tables. For example, if you use CDM to migrate the Oracle database to DWS, CDM automatically creates a table on DWS and maps the NUMBER(3,0) field of the Oracle database to the SMALLINT field of DWS.
Figure 1 Field mapping in automatic table creation
Table 1, Table 2, Table 3, and Table 4 describe the field type mapping between Hive tables and source tables when CDM automatically creates tables in Hive. For example, if you use CDM to migrate the MySQL database to Hive, CDM automatically creates a table on Hive and maps the YEAR field of the MySQL database to the DATE field of Hive.
  • For the DECIMAL type, if the length of the source data exceeds the Hive length, the precision may be lost.
  • For the DECIMAL type, the precision is greater than or equal to 1 and less than or equal to 38, and the scale is greater than or equal to 0. If the precision for the source is greater than 38 bits, the precision for Hive table creation is 38 bits. If the scale is less than 0, the scale for Hive table creation is 0. In this case, precision loss may occur after data is written.
Table 1 Field mapping in automatic table creation for MySQL-to-Hive migration
Data Type (MySQL)
Data Type (Hive)
Value
tinyint(1), bit(1)
BOOLEAN
TINYINT
SMALLINT
TINYINT UNSIGNED
SMALLINT
SMALLINT
SMALLINT
SMALLINT UNSIGNED
INTEGER
MEDIUMINT
INTEGER
MEDIUMINT UNSIGNED
BIGINT
INT
INTEGER
INT UNSIGNED
BIGINT
BIGINT
BIGINT
BIGINT UNSIGNED
DECIMAL(38,0)
DECIMAL(P,S)
DECIMAL(P,S)
The MySQL database supports a maximum of 65 bits. For Hive, the precision is greater than or equal to 1 and less than or equal to 38, and the scale is greater than or equal to 0. If the precision for the MySQL database is greater than 38 bits, the precision for Hive table creation is 38 bits. If the scale is less than 0, the scale for Hive table creation is 0.
FLOAT
FLOAT
FLOAT UNSIGNED
FLOAT
DOUBLE
DOUBLE
DOUBLE UNSIGNED
DOUBLE
Time
DATE
DATE
YEAR
DATE
DATETIME
TIMESTAMP
TIMESTAMP
TIMESTAMP
TIME
STRING
Character
CHAR(N)
CHAR(N*3)
If the value of (n*3<255) is greater than 255 (CHAR_MAX_LENGTH), varchar(N*3) is created. If the value of (n*3<255) is greater than 65535 (VARCHAR_MAX_LENGTH), a string is created.
VARCHAR(N)
VARCHAR(N*3)
If the value is greater than 65535 (VARCHAR_MAX_LENGTH), a string is created.
BINARY
BINARY
VARBINARY
BINARY
TINYBLOB
BINARY
MEDIUMBLOB
BINARY
BLOB
BINARY
LONGBLOB
BINARY
TINYTEXT
VARCHAR(765)
MEDIUMTEXT
STRING
TEXT
STRING
LONGTEXT
STRING
STRING
Table 2 Field mapping in automatic table creation for Oracle-to-Hive migration
Data Type (Oracle)
Data Type (Hive)
Character
CHAR(N)
CHAR(N*3)
VARCHAR(N)
VARCHAR(N*3)
VARCHAR2
VARCHAR(N*3)
NCHAR
CHAR(N*3)
NVARCHAR2
STRING
Value
NUMBER
DECIMAL(P,S)
For Hive, the precision is greater than or equal to 1 and less than or equal to 38, and the scale is greater than or equal to 0. If the values of precision and scale are beyond their respective ranges, a string is created.
BINARY_FLOAT
FLOAT
BINARY_DOUBLE
DOUBLE
FLOAT
FLOAT
Time
DATE
TIMESTAMP
TIMESTAMP
TIMESTAMP
TIMESTAMP WITH TIME ZONE
STRING
TIMESTAMP WITH LOCAL TIME ZONE
STRING
INTERVAL
STRING
Binary
BLOB
BINARY
CLOB
STRING
NCLOB
STRING
LONG
STRING
LONG_RAW
BINARY
RAW
BINARY
Other
STRING
Table 3 Field mapping in automatic table creation for PostgreSQL/DWS-to-Hive migration
Data Type (PostgreSQL/DWS)
Data Type (Hive)
Value
int2
SMALLINT
int4
INT
int8
BIGINT
real
FLOAT
float4
FLOAT
float8
DOUBLE
smallserial
SMALLINT
serial
INT
bigserial
BIGINT
numeric(p,s)
DECIMAL(P,S)
money
DOUBLE
bit(1)
TINYINT
varbit
STRING
Character
varchar(n)
VARCHAR(N*3)
bpchar(n)
CHAR(N*3)
char(n)
CHAR(N*3)
bytea
BINARY
text
STRING
Time
interval
STRING
date
DATE
time
STRING
timetz
STRING
timestamp
TIMESTAMP
timestamptz
TIMESTAMP
Boolean
bool
BOOLEAN
Other
STRING
Table 4 Field mapping in automatic table creation for SQL Server-to-Hive migration
Data Type (SQL Server)
Data Type (Hive)
Value
TINYINT
SMALLINT
SMALLINT
SMALLINT
INT
INT
BIGINT
BIGINT
DECIMAL
DECIMAL(P,S)
NUMERIC
DECIMAL(P,S)
FLOAT
DOUBLE
REAL
FLOAT
SMALLMONEY
DECIMAL(10,4)
MONEY
DECIMAL(19,4)
BIT(1)
TINYINT
Time
DATE
DATE
DATETIME
TIMESTAMP
DATETIME2
TIMESTAMP
DATETIMEOFFSET
STRING
TIME(p)
STRING
TIMESTAMP
BINARY
Character
CHAR(n)
CHAR(n*3)
VARCHAR(n)
VARCHAR(n*3)
If the value of (n*3<255) is greater than 255 (CHAR_MAX_LENGTH), varchar(N*3) is created. If the value of (n*3<255) is greater than 65536 (VARCHAR_MAX_LENGTH), a string is created.
NCHAR(n)
VARCHAR(n*3)
If the value of (n*3<255) is greater than 255 (CHAR_MAX_LENGTH), varchar(N*3) is created. If the value of (n*3<255) is greater than 65537 (VARCHAR_MAX_LENGTH), a string is created.
NVARCHAR(n)
VARCHAR(n*3)
If the value of (n*3<255) is greater than 255 (CHAR_MAX_LENGTH), varchar(N*3) is created. If the value of (n*3<255) is greater than 65538 (VARCHAR_MAX_LENGTH), a string is created.
Binary
BINARY
BINARY
VARBINARY
BINARY
TEXT
STRING
Other
STRING
