Operation History
You can view historical operations on the Operation History page. The system stores data for a maximum of three months and automatically deletes older data.
The operation history is available only in some regions. The actual operation history is subject to the console.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of the DataArts Factory console, choose .
In the production state in enterprise mode, the function entry is Operation History.
- You can perform the following operations on this page:
- Filter out historical operations in a specified time period.
- Filter out historical operations related to job names or node names by involved object (job name and node name).
- Perform a fuzzy search of historical operations.
- Filter out historical operations by operation object, operation type, operators, or status.
