Download Center
You can download or dump SQL script execution results. After downloading or dumping the SQL execution results, you can view them on the Download Center page.
On the Download Center page, you can centrally manage the execution results of SQL scripts. You can view and delete the download results, and view, download, and delete the dump results.
Records are generated on the Download Center page only when SQL scripts or single-task SQL jobs are executed.
Viewing Download and Dump Results
- The download records age out every seven days. When aged out, download records and the data dumped to OBS will be deleted.
- Operators can view only their own download records. Workspace admins can view all download records in the current workspace.
- View the script execution result.
- In the left navigation pane on the DataArts Factory console, choose Download Center.
- View the file name, operator, operation time, operation type, task status, and OBS path of local download tasks and asynchronous dump tasks.
- Click
in the Operation column to download data from the OBS path. - Click
in the Operation column to delete download and dump records. When you click Delete, a message is displayed indicating that the record cannot be downloaded after being deleted. Click OK.
- Filter records by search criteria.
You can filter records by time period, operation type, and task status. You can enter a keyword for fuzzy search.
You can query records by file name, OBS path, or operator, and enter a keyword for fuzzy search.
Setting the Default OBS Path
The workspace admin can set the default OBS path for dump for the current workspace.
After you set the default OBS path, the test running results of scripts or single-task jobs will be dumped to this path by default. However, the paths where previous running results have been dumped will not change.
- Click Set Default OBS Path.
- Set the default OBS path. Figure 3 Setting the default OBS path
- Click OK.
