Review Center
For a workspace in simple mode, you can set the reviewer for the scripts and jobs you submit. In the review center, you can manage applications and configure and maintain reviewers for workspaces.
- Only the administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions can create, modify, and delete reviewers.
- The reviewer must be the administrator of the current workspace or a user with the DAYU Administrator or Tenant Administrator permissions.
- If the current workspace is in enterprise mode, you can publish tasks for approval, but cannot submit scripts or jobs for approval.
- If the review function is enabled, the reviewer attribute must be added to the request body of related APIs. For details, see Job Development APIs.
- You can only set whether to enable the review function and review jobs and scripts on the console.
- If there are real-time pipeline jobs, review cannot be enabled.
- If the review function is enabled, the review center is visible to both reviewers and request submitters. If the review function is disabled, Review Center is available only to the administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions.
- The administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions cannot review their own applications.
Review Settings
Only the administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions can configure review parameters. When the review function is enabled, you can configure review options for jobs or scripts.
- In the left navigation pane, choose Review Center. In the right pane, click the Review Configuration tab.
- Enable Review. Only the administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions can enable or disable the review function.
- If you enable this function, you must specify a reviewer when submitting a job or script. If you disable this function, no jobs or scripts will need reviewing.
- If the current workspace has applications that have not been reviewed, the review function cannot be disabled.
- You can set Review Configuration to any of the following:
- All jobs/scripts: Review is enabled for all the jobs and scripts in the workspace.
- Custom jobs/scripts: You need to add the jobs or scripts that need to be reviewed.
Click the Jobs tab and click Add. On the displayed page, select the jobs for which you want to enable review. When a job is added, its associated scripts are automatically added. If you select a directory, only existing jobs in the directory are added. If you want to enable review for newly created jobs in the directory, you need to add them. Click OK.
You can delete the jobs that you have added.
Click the Scripts tab and click Add. In the displayed dialog box, select the scripts for which you want to enable review. If you select a directory, only existing scripts in the directory are added. If you want to enable review for newly created scripts in the directory, you need to add them. Click OK.
You can delete scripts that you have added.
- Baseline task jobs: Add jobs to be reviewed from baseline tasks.
Click the Jobs tab and then Add. On the displayed page, select the priority jobs of the baseline task as the jobs that require review. Then click OK. The upstream jobs of the baseline task also need to be reviewed.
Click the Scripts tab and select the jobs corresponding to the baseline. The scripts associated with the jobs will be displayed on this page.
- In the Review Information area, the administrator of the current workspace or users with the DAYU Administrator or Tenant Administrator permissions can configure reviewer information.
- Click Manage Reviewer.
- Locate the current workspace and click Edit in the Operation column.
- Next to Workspace Members, click Add.
- Search for and select a member account and select the admin role for it.
- Click OK. The configured reviewer information is automatically displayed.
Review Management
- If you have submitted a review application, you can view the review progress on the Review Center page.
- In the left navigation pane, choose Review Center. In the right pane, click the My Applications tab.
- Click View Details in the Operation column to view details about an application.
- Click Withdraw in the Operation column to withdraw an application. You can submit the application again after modifying it.
- You can view the applications pending your review.
- In the left navigation pane, choose Review Center. In the right pane, click the Pending Review tab. On this page, you can view the applications that need to be reviewed.
- Click Review in the Operation column to view the application details and review the application.
- Enter comments and approve or reject the application.
- You can view the applications that you have reviewed.
- In the left navigation pane, choose Review Center. In the right pane, click the Reviewed tab. On this page, you can view the applications that you have reviewed.
- Click View Details in the Operation column to view the review history and content of an application.
