Updated on 2026-03-20 GMT+08:00
From RestApi
If the source link of a job is a RestApi link, configure the source job parameters based on Table 1.
Table 1 Parameter description
Type
Mandatory
Example Value
Basic parameters
Requested Data Path
Path of the requested data
Yes
/api/getUsers
Request Method
Request method. The value can be GET or POST.
Yes
GET
Request Header
This header and the connection header will be combined to form the task header.
The header follows this format: {"Content-Type":"application/json"}.
Yes
Request Body
This parameter is available when Request Method is POST.
The request body is in JSON format.
Yes
{"namePrefix":"test"}
Paging Interface
Whether the interface is a paging interface
Yes
Records Obtained Each Time
This parameter is displayed when Paging Interface is set to Yes.
It indicates the number of data records obtained each time.
Yes
1000
Page Size
In indicates the page size.
  • By default, this parameter is placed in query parameters. The value of this parameter is the number of records obtained each time.
  • If body parameters include this parameter, its value will be replaced by the number of records pulled each time.
Yes
pageSize
Page Number
In indicates the page number.
  • By default, this parameter is placed in query parameters. The value of this parameter is the page number.
  • If this parameter is included in body parameters, its value will be replaced with the page number.
Yes
pageNumber
Data Path
Location of data in the response JSON body. The default value is the root path.
For example, if the response body is {"data":{"students":[{"customerConfig":{"flavorType":"cdm.large","clusterName":"mppdbCluster"}}]}} and the second-layer students data needs to be parsed, set this parameter to data.students.
No
data.students
Data Records
It indicates the total number of data records. The value can be a fixed value or obtained using an API. the interface. The value can also be a SpEL expression.
  • Fixed value
  • Obtain using an API: data.pageCount
    If you want to call a non-pagination API only once, set the value of this parameter to less than or equal to the number of data records obtained each time.
Yes
Recommended fixed value: 1,000
