Common Operation Buttons
Notebook Operation Buttons
| Button | Description |
| Run All | Runs all cells. |
| Save | Saves all cells. |
| Submit to Project Directory | Submits personal notebook files in the notebook environment directory to the project directory (job directory tree). For details, see Submitting a Notebook Environment Directory to the Project Directory. |
| New Cell | Creates a cell. |
| Clear Outputs | Clears the execution results of all cells. |
| More > Restart Kernel | Restarts the Notebook kernel. |
| More > Kill Kernel | Stops the Notebook kernel. |
| Shift+Enter | Runs the current cell and moves to the next cell. |
| Esc+H | Views all keyboard shortcut keys. |
| Code Execution Mode | Description |
| Run cell | Runs codes in the entire cell. |
| Run all above | Runs all cells above the current cell. |
| Run all below | Runs the current cell and all cells below it. |
| Run selected text | Runs selected text. |
| Common Function Button | Description |
| Python | The supported languages include Python and Markdown. |
| Ctrl + Shift + C | Copies a cell. |
| Ctrl + Shift + V | Pastes a copied or cut cell. |
| Ctrl + Shift + X | Cuts a cell. |
| Alt + P | Adds a cell above the current cell. |
| Alt + N | Adds a cell below the current cell. |
| Alt + UpArrow | Moves a cell up. |
| Alt + DownArrow | Moves a cell down. |
| Alt + Delete | Clears the cell execution result. |
| Mark as Parameters Cell | Marks a cell as a Parameters cell. The Parameters cell previously marked will be invalid. |
| Deletes the current cell. |
| Maximizes the code development window. After the window is maximized, only the current cell is displayed. |
| Minimizes the code development window. After the window is minimized, you can view all cells. |
| After maximizing the window, you can click |
| Click Click |
| Creates a cell. You can also create a cell between two cells. |
Common Operation Buttons in the Notebook Environment Directory
| Common Operation | Description |
| Creates a folder or notebook. |
| Refreshes the notebook environment directory tree. |
| Locates the file tree. It allows you to find the specific location of the notebook file you are editing in the notebook environment directory tree. |
| Collapses My Files. Expands My Files. |
| Folder - New Notebook | Creates a notebook file. You can also right-click My Files to create a notebook file. |
| Folder - New Folder | Creates a subfolder in a folder. You can also right-click My Files to create a folder. |
| Folder - Upload File | Uploads a notebook file to a folder. You can also right-click My Files to upload a notebook file. The file to be uploaded must be in xxxxx.ipynb format. |
| Folder - Delete | Deletes a folder. The notebook files in the folder will be deleted along with it. |
| Folder - Copy Name | Copies the name of a notebook folder. |
| Folder - Rename | Renames a folder. |
| Notebook file - Open | Opens a notebook. |
| Notebook file - Copy Name | Copies the name of a notebook. |
| Notebook file - Rename | Renames a notebook. |
| Notebook file - Export | Exports a notebook. The exported notebook file is in xxxxx.ipynb format. You can upload the exported notebook file to a specified directory. |
| Notebook file - Move to | Moves a notebook. You can move a notebook to another folder. |
| Notebook file - Delete | Deletes a notebook. |
