Updated on 2026-03-20 GMT+08:00
To HDFS
Table 1 Parameter description
Type
Example Value
Basic parameters
Write Directory
HDFS directory to which data will be written.
/user/cdm/output
File Format
Format used for transmitting data. The CSV and JSON formats are supported for migration to tables, and the binary format is supported for file migration.
CSV
Newline character processing mode
Policy for processing newline characters when the data written to a text file table contains newline characters (\n|\r|\r\n)
  • Delete
  • Ignore
  • Replace with another string
Delete
Newline Replacement String
It indicates the string that will replace newline characters.
N/A
Advanced attributes
Write to Temporary File
This parameter is displayed only when File Format is set to Binary.
It indicates writing the binary file to a temporary file whose name extension is .tmp.
No
Line Separator
This parameter is displayed only when File Format is set to CSV.
It indicates the line feed character in a file. By default, the system automatically identifies \n, \r, and \r\n. You can configure special characters. For spaces and carriage returns, encode them with URL. You can also configure them by editing the job JSON, in which case URL encoding is not required.
\n
Field Delimiter
Field delimiter in the file. Special characters must be encoded using URLs.
Job Success Marker File
Marker file name
When the job is successful, a marker file is generated in the destination directory. If this parameter is left blank, no marker file will be generated.
finish.txt
Use Quote Character
Quote characters are used to enclose a string value. Field separators in the quote characters are regarded as a part of the string value. Only quotation marks (") can be used as quote characters.
No
Customize Hierarchical Directory
Users can customize the directory hierarchy of files.
Example: [Table name]/[Year]/[Month]/[Day]/[Data file name]. csv
No
This parameter is displayed when Customize Hierarchical Directory is set to Yes.
Used to specify the directory level of a file, with time macro supported (the time format is yyyy/MM/dd). If the source link is a relational database link, the directory name consists of the source table name and a custom directory name. In other scenarios, the directory is a custom directory.
${dateformat(yyyy/MM/dd, -1, DAY)}
File Name Prefix
Prefix of the file name.
File name format: prefix-jobname-timestamp-index
data
Compression Format
Compression format of the file to be written
  • NONE
  • DEFLATE
  • GZIP
  • BZIP2
  • SNAPPY
SNAPPY
Encryption
Encryption mode for the uploaded data
  • None
  • AES-256-GCM
None
DEK
This parameter is displayed when File Format is set to Binary and Encryption Mode is set.
It indicates the data encryption key. The AES-256-GCM key consists of 64 hexadecimal digits.
DD0AE00DFECD78BF051BCFDA25BD4E320DB0A7AC75A1F3FC3D3C56A457DCDC1B
IV
It indicates the initialization vector, which consists of 32 hexadecimal digits.
5C91687BA886EDCD12ACBC3FF19A3C3F
