To Redis
| Type | Parameter | Description | Example Value |
| Basic parameters | Redis Key Prefix | Corresponding to the table name of a relational database | TABLENAME |
| Value Storage Type | The value can be STRING, hash, list, set, or zset. | STRING | |
| Delete Same Key Before Writing | Whether to delete the same key before writing | No | |
| Advanced attributes | Key Delimiter | Used to separate table names and column names of a relational database | _ |
| Value Delimiter | Used to separate columns when the storage type is string. It is the character used to split a string into arrays when the storage type is list. | ; | |
| Key Value Validity Period | Validity period of the key, in seconds | 3600 |
