From Redis
| Type | Parameter | Description | Example Value |
| Basic parameters | Redis Key Prefix | Corresponding to the table name of a relational database | TABLENAME |
| Value Storage Type | The storage type can be STRING or HASH. | STRING | |
| Advanced attributes | Key Delimiter | Used to separate table names and column names of a relational database | _ |
| Value Delimiter | Used to separate columns when the storage type is string. It is the character used to split a string into arrays when the storage type is list. | ; | |
| Same Field | Whether duplicate fields are allowed in a hash key. This parameter is displayed when Value Storage Type is set to HASH. | No |
