Updated on 2025-11-18 GMT+08:00
Managing Notebooks
After enabling notebooks, you can use notebooks to develop, debug, and schedule jobs in clusters. You can also explore, process, and visualize data in real time. In addition, you can configure the notebook quota in a workspace.
Notes and Constraints
Only the workspace administrator or users with the DAYU Administrator or Tenant Administrator permission can enable notebooks.
Enabling Notebooks
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane, choose Configuration > Configure.
  4. Choose Notebook Management.
  5. Enable Notebooks.
  6. When the notebook is being enabled, the following message is displayed: "Notebooks are being initialized. It takes about 20 minutes."
    The notebooks you create are displayed in the list. After notebooks are enabled, you can use it on the Notebook page in DataArts Factory.
    You can perform the following operations on notebooks:
    Click Delete in the Operation column to delete a notebook that is no longer needed.
    Click Stop in the Operation column to stop a running notebook.
Managing the Quota
You can set the maximum number of notebooks allowed for the current workspace. The total quota of all workspaces cannot exceed the quota of the DataArts Studio instance.
  1. Click Manage Quota.
  2. Set Notebooks.
    Figure 1 Configuring the quota
    Set Notebooks to a value greater than the number of existing notebooks and less than the maximum number of notebooks allowed for the current workspace. For example, if a maximum of six notebooks are allowed in the current workspace, you can set Notebooks to 6.
  3. Click OK.
