Help Center/
DataArts Studio/
User Guide/
DataArts Factory/
Notebook Development/
Using a Notebook Instance to Develop and Debug Code Online/
Developing a Notebook Task
Updated on 2025-04-28 GMT+08:00
This section describes how to develop tasks using a notebook instance.
Notebooks are enabled, and a notebook instance has been created. For how to create a notebook instance, see Creating a Notebook Instance.
- In the navigation pane on the DataArts Factory console, choose Data Development > Notebook.
- Locate a running notebook instance.
- Click Open to go to the notebook development page.
- Click
and select Notebook to create a notebook file. Add an .ipynb file to create a notebook. Then develop a notebook.
- On the notebook development page, enter and debug development code.
- You can save, insert data below, cut, copy, paste, run, and interrupt data.
- You can click
in front of a line to run the code. - Three types of code display styles are supported: Code, Markdown, and Raw.
- You can insert data below, move up, move down, and delete code lines.
- Click
to run the code. - View the code execution result.
