Updated on 2025-09-09 GMT+08:00
Overview
Notebooks are available for restricted use. To use them, contact customer service or technical support.
This function is available only in AP-Singapore, AP-Bangkok, and LA-Santiago.
DataArts Studio Notebook is an interactive development environment that provides fully managed, out-of-the-box JupyterLab on the cloud. It helps data engineers and data scientists easily develop, debug, and schedule jobs in clusters. It also supports real-time data exploration, processing, and visualization.
Notebook is an interactive data analysis and mining module that has been deeply optimized based on the open-source JupyterLab. It provides online development and debugging capabilities for writing and debugging model training code. After interconnecting DataArts Studio with a notebook instance, you can compile code and develop jobs in the web-based interactive development environment provided by Notebook to flexibly analyze and explore data.
For how to perform operations on Jupyter Notebook, see Jupyter Notebook Documentation.
You can develop and debug DataArts Studio jobs online and use notebook instances to submit the jobs. You can perform data analysis and exploration seamlessly, without the need to set up a development environment.
Before using this function, you must enable notebooks. If notebooks are not enabled, message "Notebooks disabled." is displayed. For details about how to enable notebooks, see Managing Notebooks.
If notebooks are disabled in the current workspace, contact the administrator to enable notebooks. Users with the DAYU Administrator or Tenant Administrator permission can also enable notebooks.
