Viewing User Permissions (Member Permission View) (Advanced Feature)
DataArts Security allows you to view the permission list. You can view the permissions obtained by users or user groups in a workspace of the current instance through roles (including workspace permission sets, permission sets, and roles) or the permission application and approval process.
In the new version mode, the member permission view is supported only in the enterprise version. In the old version mode, this function is supported in the basic version or an advanced version.
Notes and Constraints
- Permissions of users inherited from user groups are not displayed.
- Permissions cannot be directly configured or revoked on the Member Permission View page.
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Data Security Operations > Member Permission View. Figure 1 Member Permission View page
- On the Member Permission View page, select a user or user group in a workspace (you can filter users or user groups by workspace, user, or user group). By default, the permissions obtained by the user or user group through roles (including workspace permission sets, permission sets, and roles) or the permission application and approval process are displayed. You can filter permissions by data source type and search for permissions by cluster name, database name, schema, table name, function name, or column name. Figure 2 Viewing user permissions
