Authorizing dlg_agency
Cloud service agencies allow DataArts Studio to perform operations such as task scheduling and resource O&M on other cloud services on your behalf. For details about how to create the default dlg_agency, see Creating the dlg_agency (Default Agency).
When using an agency, DataArts Security requires higher cloud service permissions. Before using DataArts Security, you need to grant the permissions listed in Table 1 to dlg_agency.
Permission |
Purpose |
Mandatory |
Authorization Item/System Permission (Configure Either of Them) |
IAM permission |
This permission is required for the system to obtain users or user groups, or create roles. For example, user or permission synchronization fails if this permission is missing. |
Mandatory for MRS, DWS, and DLI permission management |
Due to the restrictions of permission policies in IAM, no action is available for obtaining DLI user groups. To manage the permissions of DLI user groups, you must grant the Security Administrator system permissions. |
Security Administrator |
MRS/DWS data connection agent permission |
This permission is required for permission synchronization. For example, if this permission is missing, permission synchronization between permission sets, role permission synchronization, or permission application approval fails. |
Mandatory for MRS and DWS permission management |
Any CDM permission, for example, cdm:cluster:get |
Any CDM permission, for example, CDM Administrator |
MRS user synchronization permission |
This permission is required for MRS user synchronization. For example, MRS user synchronization fails if this permission is missing. |
Mandatory for MRS permission management |
MRS FullAccess |
DWS user synchronization permission |
This permission is required for DWS user synchronization. For example, DWS user synchronization fails if this permission is missing. |
Mandatory for DWS permission management |
DWS FullAccess |
Applying for DWS data permissions in Data Map |
This permission is required for applying for DWS data permissions in Data Map. |
Mandatory for applying for DWS data permissions in Data Map. |
Any DWS permission except DWS Database Access, for example, DWS ReadOnlyAccess |
DLI permission synchronization permission |
This permission is required for DLI permission synchronization and sensitive data discovery. For example, if this permission is missing, DLI permission synchronization fails and the system displays a message indicating insufficient permissions. |
Mandatory for DLI permission management |
Actions are not supported. System permissions DLI FullAccess and DLI Service Administrator are required. |
In the dialog box displayed on the DataArts Studio console homepage, you have selected Agree to allow the system to automatically create an agency named dlg_agency.
After the agency authorization is successful, it takes 15 to 30 minutes for the permissions to take effect. Then, you can use DataArts Security to manage access permissions.
Granting Permissions to dlg_agency
When granting permissions to dlg_agency, you need to select either an authorization item or system permission from Table 1 as needed.
This section uses the MRS permission management scenario as an example. The permissions to be granted include the IAM permission, MRS/DWS data connection agent permission, and MRS user synchronization permission. The principle of least privilege is used. The operations are as follows:
- Log in to the IAM console.
- In the left navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
Figure 1 Clicking Create Custom Policy
- On the displayed Create Custom Policy page, select JSON for Policy View, enter the IAM custom policy content required for MRS permission management, and click OK.
A custom policy can contain permissions for either global or project-level services. You need to configure IAM policies first, and then MRS and CDM policies.
- Policy Name: Enter DataArtsIamUserGroup_IAM.
- Policy View: Select JSON to switch to the JSON view.
- Policy Content: Enter the following JSON code and click OK.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "iam:users:listUsers", "iam:groups:listGroups", "iam:users:listUsersForGroup", "iam:roles:createRole", "iam:roles:deleteRole", "iam:roles:updateRole", "iam:permissions:grantRoleToGroup", "iam:permissions:listRoleAssignments", "iam:permissions:revokeRoleFromGroup" ] } ] }
Figure 2 Creating a custom policy for IAM
- Click Create Custom Policy again. On the displayed Create Custom Policy page, select JSON for Policy View, enter the MRS and CDM custom policy content required for MRS permission management, and click OK.
- Policy Name: Enter DataArtsIamUserGroup_MRS.
- Policy Content: Enter the following JSON code.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "mrs:cluster:syncUser", "cdm:cluster:get" ] } ] }
Figure 3 Creating custom policies for MRS and CDM
- In the left navigation pane, choose Agencies, search for dlg_agency, and click Authorize.
Figure 4 Authorizing dlg_agency
- In the displayed dialog box, locate and select the created custom policies DataArtsIamUserGroup_IAM and DataArtsIamUserGroup_MRS, and click Next.
Figure 5 Selecting the created custom policies
- Click OK. After the authorization is complete, wait for 15 to 30 minutes. Then, you can use DataArts Security to manage MRS access permissions.
