Updated on 2025-09-09 GMT+08:00
Configuring an OBS Bucket
The execution history of scripts, jobs, and nodes is stored in OBS buckets. If no OBS bucket is available, you cannot view the execution history. This section describes how to configure an OBS bucket.
The OBS path is only supported for OBS buckets and not for parallel file systems.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the navigation pane, choose Configuration > Configure.
  4. Choose OBS Bucket.
  5. Select an OBS bucket.
    Figure 1 Configuring an OBS bucket
  6. Click Save.
