Execution History
This section describes how to view the execution history of scripts, jobs, and nodes over a week.
This function depends on OBS buckets. For details about how to configure OBS buckets, see Configuring an OBS Bucket.
Script Execution History
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the navigation pane of the DataArts Factory homepage, choose Data Development > Develop Script.
- Above the directory, click  to display the script and job execution history in the past seven days. to display the script and job execution history in the past seven days.
- Select Scripts from the drop-down list box to filter out the script execution history.
- Click a record to view the script information and execution result.
- Download the historic script execution result.
      - By default, all users can download the historic execution results of scripts.
- You can click Download on the Result tab page.
- You can download the result file in CSV format. A maximum of 1,000 results can be queried and downloaded.
Job Execution History
- In the left navigation pane of DataArts Factory, choose .
- Select Jobs from the drop-down list box to filter out the job execution history.
- Click a record to view the job and log information.
      If only some nodes of the job were tested, the execution history only displays information and logs for these nodes.
