MRS Impala SQL
Functions
The MRS Impala SQL node is used to execute the Impala SQL script predefined in DataArts Factory.
Impala provides fast, interactive SQL queries on your Apache Hadoop data stored in HDFS, HBase, or the Object Storage Service (OBS).
Parameters
Table 1 and Table 2 describe the parameters of the MRS Impala node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). By default, the node name is the same as that of the selected script. If you want the node name to be different from the script name, disable this function by referring to Disabling Auto Node Name Change. |
SQL Script |
Yes |
Path of a script to be executed. If no script is available, create and develop a script by referring to Creating a Script and Developing an SQL Script. |
Data Connection |
Yes |
Data connection that is configured in the SQL script. The value can be changed. |
Database |
Yes |
Database that is configured in the SQL script. The value can be changed. |
Resource Queue |
No |
Enter the resource queue name. |
Script Parameter |
No |
If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be an EL expression. If the parameters of the associated SQL script are changed, click |
Parameter |
Mandatory |
Description |
Node Status Polling Interval (s) |
Yes |
How often the system check completeness of the node. The value ranges from 1 to 60 seconds. |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
Retry upon Failure |
Yes |
Whether to re-execute a node if it fails to be executed. Possible values:
Policy for Handling Subsequent Nodes If the Current Node Fails |
Yes |
Operation that will be performed if the node fails to be executed. Possible values:
Enable Dry Run |
No |
If you select this option, the node will not be executed, and a success message will be returned. |
Task Groups |
No |
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
Parameter |
Description |
Input |
Add |
Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM. |
OK |
Click OK to save the parameter settings. |
Cancel |
Click Cancel to cancel the parameter settings. |
Modify |
Click |
Delete |
Click |
View Details |
Click |
Output |
Add |
OK |
Cancel |
Modify |
Click |
Delete |
Click |
View Details |
Click |
