Updated on 2026-08-13 GMT+08:00
MRS Presto SQL
Functions
The MRS Presto SQL node is used to execute the Presto SQL script predefined in DataArts Factory.
Presto is an open-source SQL query engine for running interactive analytic queries against data sources of all sizes.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the MRS Presto SQL node.
Table 1 Property parameters
Parameters
Mandatory
SQL or Script
Yes
You can select SQL statement or SQL script.
  • SQL Statement
    Click the text box under SQL statement and enter the SQL statement to be executed.
  • SQL Script
    Select a script to be executed. If the script is not created, create and develop the script by repeating steps Creating a Script and Developing an SQL Script.
    If you select the SQL statement mode, the DataArts Factory module cannot parse the parameters contained in the SQL statement.
    A script can transfer a maximum of 50 parameters to a job node. A parameter name can contain no more than 64 characters, and a parameter value can contain no more than 256 characters.
Data Connection
Yes
Data connection that is configured in the SQL script. The value can be changed.
Schema
Yes
Database that is configured in the SQL script. The value can be changed.
Script Parameter
No
If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be an EL expression.
If the parameters of the associated SQL script are changed, click to refresh the parameters.
Node Name
Yes
Name of the SQL script. The value can be changed.
Node name. It contains 1 to 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
The node name cannot contain Chinese characters or more than 64 characters. If the node name does not meet requirements, the MRS job will fail to be submitted.
By default, the node name is the same as that of the selected script. If you want the node name to be different from the script name, disable this function by referring to Disabling Auto Node Name Change.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
How often the system check completeness of the node. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
Yes
Whether to re-execute a node if it fails to be executed. Possible values:
  • Yes: The node will be re-executed, and the following parameters must be configured:
    • Retry upon Timeout
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node will not be re-executed. This is the default setting.
    If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
    If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
    Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
Policy for Handling Subsequent Nodes If the Current Node Fails
Yes
Operation that will be performed if the node fails to be executed. Possible values:
  • Suspend execution plans of the subsequent nodes: stops running subsequent nodes. The job instance status is Failed.
  • End the current job execution plan: stops running the current job. The job instance status is Failed.
  • Go to the next node: ignores the execution failure of the current node. The job instance status is Failure ignored.
  • Suspend the current job execution plan: If the current job instance is in abnormal state, the subsequent nodes of this node and the subsequent job instances that depend on the current job are in waiting state.
Enable Dry Run
No
If you select this option, the node will not be executed, and a success message will be returned.
Task Groups
No
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning.
Table 3 Lineage
Input
Add
Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM.
OK
Click OK to save the parameter settings.
Cancel
Click Cancel to cancel the parameter settings.
Modify
Click to modify the parameter settings. After the modification, save the settings.
Delete
Click to delete the parameter settings.
View Details
Click to view details about the table created based on the input lineage.
Output
Add
OK
Cancel
Modify
Delete
View Details
Click to view details about the table created based on the output lineage.
