ROMA FDI Job
Updated on 2024-07-11 GMT+08:00
Functions
The ROMA FDI Job node executes a predefined ROMA Connect data integration task to implement data integration and conversion between the source and destination.
Working Principles
This node enables you to start an FDI task or query whether an FDI task is running.
Parameters
The following table describes the parameters of a ROMA FDI Job node.
Table 1 Property parameters
Mandatory
Node Name
Yes
Name of the node. The value must consist of 1 to 128 characters and contain only letters, digits, and the following special characters: _-/<>
Region
Yes
Region where an existing instance resides
ROMA Instance
Yes
Select an existing ROMA instance.
You can select an ROMA instance in another resource space.
FDI Task
Yes
Select an existing ROMA FDI task.
You can select an FDI task in another resource space.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
How often the system check completeness of the node. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
Yes
Whether to re-execute a node if it fails to be executed. Possible values:
  • Yes: The node will be re-executed, and the following parameters must be configured:
    • Retry upon Timeout
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node will not be re-executed. This is the default setting.
    If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
    If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
    Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
Policy for Handling Subsequent Nodes If the Current Node Fails
Yes
Operation that will be performed if the node fails to be executed. Possible values:
  • Suspend execution plans of the subsequent nodes: stops running subsequent nodes. The job instance status is Failed.
  • End the current job execution plan: stops running the current job. The job instance status is Failed.
  • Go to the next node: ignores the execution failure of the current node. The job instance status is Failure ignored.
  • Suspend the current job execution plan: If the current job instance is in abnormal state, the subsequent nodes of this node and the subsequent job instances that depend on the current job are in waiting state.
Enable Dry Run
No
If you select this option, the node will not be executed, and a success message will be returned.
Task Groups
No
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning.
