Viewing a Job Dependency Graph
You can view a job dependency graph to learn the upstream and downstream jobs associated with the job.
Dependent jobs have been configured in the job scheduling configuration in Developing a Pipeline Job. Otherwise, only the current job node can be displayed in the view, and the associated upstream and downstream job nodes cannot be displayed.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the job directory, right-click the job you want to view and select View Job Dependency Graph.
Figure 1 Development-State Job Dependency View page
- On the displayed Development-State Job Dependency View page, perform any of the following operations:
- Select Display complete dependency graphs, Display the current job and its upstream and downstream jobs, or Display the current job and its directly connected jobs.
- You can search for a job by name. The job found is highlighted.
- Click Download to download the job dependency file.
- Scroll your mouse wheel to zoom in or zoom out the dependency graph.
- Drag the blank area to view the complete relationship graph.
- When the cursor is hovered on a job node, the node is marked green, its upstream job is marked blue, and its downstream job is marked yellow.
Figure 2 Marking upstream and downstream job nodes of a node
- Right-click a job node to view the job, copy the job name, and collapse upstream or downstream jobs.
Figure 3 Job node operations
Viewing the Job Dependency Graph
- Right-click the job directory and select View Job Dependency Graph.
Figure 4 Viewing the job dependency graph
- The system displays the dependencies between all the jobs in the directory. You can search for jobs by name. The matched jobs will be highlighted.
- If you click a node in the dependency graph, its upstream jobs are marked blue and its downstream jobs are marked yellow.
- You can drag to view the full dependency graph.
- Scroll the mouse wheel to zoom in or out the dependency graph.
