Embedding Data Watermarks
This section describes how to embed data watermarks. Data watermarking applies to the following scenarios:
- Data forwarding process standardization
Unauthorized users need to be approved when they forward data from enterprises for external usage. After the approval, the watermark technology is used to generate files that can be used outside enterprises.
- Digital right protection
To associate databases with their owners, embed watermarks representing ownerships in relational databases. In this way, enterprises' digital rights can be protected.
- Quick source tracing of leaked data
To locate security vulnerabilities, unseal the leaked data files, check whether watermarks exist based on the file integrity and watermark traces, and identify watermark information such as data source addresses, distribution units, owners, and distribution time.
Watermark Use Process
Figure 1 shows the process of using watermarks.
- Only the MRS Doris and MRS Hive data sources support data watermark tasks.
- Watermarks cannot be embedded into a primary key.
- A pseudocolumn watermark can be of the numeric or character type, and a maximum of five pseudocolumns can be generated.
- If a watermark is embedded in a numeric integer field, the data may be modified. Embed watermarks into a field whose value can be changed.
- If Dataset Scope is set to Incremental for a data watermark embedding task, Timestamp or Date needs to be selected for Time Field.
- For the MRS Doris data source, watermarks can be embedded only into fields of the string type, including Varchar, Text, and String. Ensure that the table into which watermarks are to be embedded contains fields of the string type.
- To embed watermarks into the MRS Doris data source, you need to prepare an MRS cluster that contains the Hadoop, Spark, and Yarn components. The MRS cluster is used to run the watermark embedding task.
An MRS Hive or MRS Doris connection has been created. For details, see Creating a DataArts Studio Data Connection.
Creating a Data Watermark Embedding Task
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- Choose from the left navigation bar, and click Create in the upper part of the displayed page.
Figure 2 Creating a data watermark embedding task
- In the displayed dialog box, set the parameters listed in Table 1.
Table 1 Basic settings Parameter
*Task
Name of the watermark embedding task. The name can only contain letters, digits, underscores (_), and hyphens (-), and can contain a maximum of 64 characters.
To facilitate the management of the watermark embedding task, you are advised to include the object into which you want to embed the watermark and the watermark ID in the name.
A description of the task
*Watermark ID
Watermark ID that will be embedded by the system into data tables. The watermark ID can contain a maximum of 16 characters.
*Error Correction Level
The higher the level, the more bits of watermark information, and the lower bit error rate during source tracing. Note that a higher error correction level requires a larger amount of data to ensure the integrity of embedded information. The default value is 1.
*Watermark Version
V1: Watermarks depend on primary keys, and the embedding speed is fast. If primary keys are attacked, source tracing may fail.
V2: Watermarks do not depend on primary keys. They are related only to embed columns. The embedding speed is slow and the robustness is enhanced.
*Watermark Type
Watermark type.
- Raw column watermark: Watermarks are embedded into raw columns of tables. When a watermark is embedded in a numeric integer column, data may be modified.
- Pseudocolumn watermark: An attribute (pseudocolumn, such as a virtual ID) that does not exist in the raw table is constructed, and watermarks are embedded into the attribute.
Figure 3 Configuring basic information
- Click Next to configure the source and target end parameters listed in Table 2.
Table 2 Source and target end parameters Parameter
Source Settings
*Data Source Type
Currently, the value can only be MRS Hive or MRS Doris.
*Data Connection
Select a data connection. If no data connection is available, create one by referring to Creating a DataArts Studio Data Connection.
*HTTP/HTTPS Port
This parameter is required for the MRS Doris data source. To obtain the port, perform the following operations: Log in to MRS FusionInsight Manager of the Doris cluster, choose Cluster > Services > Doris, and click Configurations. If Kerberos authentication is enabled for the cluster, enter the value of https_port for this parameter. Otherwise, enter the value of http_port for this parameter.
*Database
Select the databases and tables into which you want to embed the watermark.
- Click Configure to select databases and tables.
- Click Clear to delete the selected databases and data tables.
*Source Table
*Watermark Embedding Bar
Select a field type from the drop-down list as the embedding bar. For example, the value can be a number or a character.
Note that when Watermark Version is set to V1, the primary key column cannot be selected.
*Dataset Scope
If Dataset Scope is set to Incremental, you can set Time Field to Timestamp or Date.
Generally, the watermark embedding task is scheduled once if this parameter is set to All and is scheduled periodically if this parameter is set to Incremental.
*Time Field
If Dataset Scope is set to Incremental, you can set this parameter to Timestamp or Date.
Target End Settings
*Data Source Type
Currently, only MRS Hive and MRS Doris are supported. The value must be the same as that of the source.
*Data Connection
*HTTP/HTTPS Port
*Database
Select the database where the watermark table is stored from the drop-down list.
*Pseudocolumn
This parameter is displayed when Watermark Type is set to Pseudocolumn watermark.
Construct a pseudocolumn attribute that does not exist in the raw table.
- Column Name: name of the pseudocolumn. It can contain 1 to 63 characters, including only letters, digits, and underscores (_). It must be unique.
- Data Type: Only Numeric Value Type and String are supported.
- Field Rule:
- If Data Type is Numeric Value Type, the value of Random Number Range can range from -2,000,000,000 to 2,000,000,000 (integers only). If you do not set this parameter, the value ranges from 0 to 2,000,000,000 by default. If the value of Random Number Precision is empty or 0, this field is an integer. If the value is greater than 0, this field is a floating-point number.
Note: If watermarks are embedded in numeric integer columns, the data may be modified. As a result, the values in the target table may not be within the specified range.
- If Data Type is String, select more than 30 built-in algorithms to generate pseudocolumn data.
*Target Table
Enter a unique table name. The table is automatically created when the table name entered does not exist.
Click Test. Otherwise, the next operation is not allowed.
Compute Engine
*Computing Engine
Select a computing engine from the drop-down list box when the data source type is MRS Doris.
Figure 4 Configuring source and target information
- Click Next and configure scheduling.
- If Dataset Scope is set to All, Repeat can be only set to Once.
- If Dataset Scope is set to Incremental, Repeat can be set to Once or On Schedule.
If you set Repeat to On Schedule, set the parameters listed in Table 3.
Table 3 Parameters for periodic scheduling Parameter
*Date
Period during which the task takes effect.
*Cycle
The frequency at which a task is executed. The options are:
- minutes: Select the scheduling start time and end time, and set the interval in minutes.
- hours: Select the scheduling start time and end time, and set the interval in hours.
- Day: Set the scheduling time everyday.
- Week: Select a day in a week and set the specific time to start scheduling.
- Month: Select a day in a month and set the specific time to start scheduling.
For example, you can set Cycle to Week, Time to 15:52, and Time Range to Tuesday. In this case, the task is executed at 15:52 every Tuesday within the configured date range.
Start now
If you select Start now, the task is scheduled immediately.
Figure 5 Configuring scheduling
- Click OK.
Related Operations
- Editing a task: On the Data Watermark Embedding page, locate a task and click Edit in the Operation column.
A task in the Scheduling state cannot be edited.
- Deleting tasks: On the Data Watermark Embedding page, locate a task, click More in the Operation column, and select Delete. To delete multiple tasks at a time, select the tasks and click Delete above the task list.
A task in the Scheduling state cannot be deleted.
The deletion operation cannot be undone. Exercise caution when performing this operation.
- Running or scheduling a task: On the Data Watermark Embedding page, locate a task and click Run in the Operation column or click More in the Operation column and select Start.
You can determine whether a task is scheduled once or repeatedly based on the scheduling period.
- Viewing running instance logs: On the Data Watermark Embedding page, locate a task and click
to expand instances. Then click View Log.
If a task fails to be executed, you can locate the failure cause based on logs, rectify the fault, and try the task again. If the fault persists, contact technical support.
