Creating Data Security Levels
To facilitate data management, you need to create data security levels and describe data confidentiality, for example, you can specify the application scope of your data. This section describes how to define data security levels and configure the default security level.
Data security levels, data classifications, and identification rules are DataArts Studio instance-level configurations and can be exchanged between workspaces. In this way, data can be managed based on unified standards in the Data Map component.
At least one security level has been created based on Creating a Security Level.
- According to the industry common practice, a larger number indicates a higher security level. A maximum of 10 security levels can be created.
- Only the DAYU Administrator, Tenant Administrator, or data security administrator can create, modify, or delete data security levels, classifications, and identification rules. Other common users do not have permission to perform these operations.
- After the default security level is configured, it applies to all the data tables and fields (including inventory and incremental data) that have no security levels in MRS Hive and DWS data sources. The default security level can be displayed in Data Map and can be used to control permissions for data preview based on Managing Sensitive Data.
The security levels displayed during permission requests are from Data Map and include the default security level. The security levels displayed during static and dynamic masking are from sensitive data discovery tasks and do not include the default security level.
- Data security levels that are referenced can be deleted only if the reference is canceled.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Sensitive Data Identification > Data Confidentiality. Figure 1 Data Confidentiality page
- On the displayed page, click Create and set the parameters listed in Table 1. Figure 2 Creating a data security level
Table 1 Parameters Parameter
*Name
The security level name can include only letters, numbers, and underscores (_). After a security level is created, its name cannot be edited.
All characters can be entered in a security level description. After a security level is created, you can edit its description.
By default, security levels are displayed in ascending order. You can also move a security level up or down as required.
Configuring the Default Security Level
You can configure the default security level for the assets in MRS Hive and DWS data sources.
- In the navigation pane on the left, choose Sensitive Data Identification > Data Confidentiality. Figure 3 Data Confidentiality page
- Select a security level from the Default Security Level drop-down list box in the upper right corner as the default security level. After the default security level is configured, it applies to all the data tables and fields (including inventory and incremental data) that have no security levels in MRS Hive and DWS data sources. The default security level can be displayed in Data Map and can be used to control permissions for data preview based on Managing Sensitive Data.
Figure 4 Creating a data security level
Related Operations
- Adjusting a security level: On the Data Confidentiality page, locate a security level, click More in the Operation column, and select Up or Down.
- Editing a security level: On the Data Confidentiality page, locate a security level and click Edit in the Operation column to change the description of the security level.
- Deleting one or more security levels: On the Data Confidentiality page, locate a security level and click Delete in the Operation column to delete the security level. To delete multiple security levels, select them and click Delete above the list.
- The deletion operation cannot be undone. Exercise caution when performing this operation.
