Unlocking a Job
DataArts Factory provides the lock function, which allows you to unlock scripts and jobs.
- You can view the lock status of a script or job in the script or job directory tree.
- To view the latest saved or submitted content of a script or job locked by another user, you need to re-open the script or job because it is not updated in real time.
- After the DataArts Studio lock function became available, previously created scripts or jobs remain unlocked by default. To edit, save, or submit these scripts or jobs, you need to lock them first.
- The locking operation depends on the soft and hard lock policies. For details about how to configure soft and hard lock policies, see Configuring Default Items.
- Soft lock: You can lock or unlock jobs or scripts, regardless of whether they are locked by others.
- Hard Lock: You can lock jobs or scripts only after they have been unlocked by other users. The workspace administrator and DAYU Administrator can lock and unlock jobs or scripts without any limitations.
- Do not lock a script or job that is locked by another user because if you do so, changes to the script or job made by the user will be lost. If you want to modify the script or job, contact the user to unlock the script or job, and lock it by yourself.
A job has been developed.
If you submit a version, the latest job in the development state will be saved and submitted and overwrite the previous job version. You are advised to unlock the job after submitting the version so that other developers can modify the job as needed.
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the job directory, double-click the developed job to access the job development page.
- Above the job canvas or editor, click Unlock to unlock the job. Figure 2 Unlocking a job
