Submitting a Version
Submitting a version depends on the version management function of DataArts Factory.
- Development state: Scripts or jobs have not been submitted and are used for debugging. In the development state, you can edit, save, and run scripts or jobs without affecting those being scheduled. In addition, when a job is being associated with a script or job dependency is being configured, the associated script or job will read the configuration in the development state.
- Production state: Script or jobs have been submitted and are used for formal scheduling. In formal scheduling, the latest submitted versions of scripts or jobs will be used in scenarios such as script invocation, instance rerunning, and job dependency and patch data configuration.
A script has been developed.
Submitting a Script Version
If you submit a version, the latest script in the development state will be saved and submitted and overwrite the previous script version.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the script directory, double-click the developed script to access the script development page.
- Above the script editor, click Submit to submit a version. Select a reviewer, enter a description of a maximum of 128 characters, and select the message. If you do not select the message, you cannot click OK. When submitting a version, you can click Compare Version to view the differences between the current version and the last version. Figure 1 Submitting a version
- If review is enabled on the Review Center page, your submitted version will be reviewed by the reviewer on the Pending Review tab page on the Review Center page. The version is submitted successfully only after it is approved by the reviewer. For details, see Approval Settings. If review is disabled, the version can be directly submitted.
To revoke a submitted request, go to the Review Center page and click the My Applications tab. Then you can submit an application again.
- If review is enabled, the following operations need to be reviewed: submitting scripts, deleting scripts, and importing submitted scripts.
- Before disabling the review function, ensure that there are no requests pending review in the current workspace.
- The enterprise mode does not support the review function.
Version Rollback
After submitting the version, you can view it in the version list. (Currently, a maximum of 100 latest versions are saved.) Click Roll Back to roll back to any submitted version.
- DLI: data connections, databases, resource queues, and script contents
- DWS: data connections, databases, and script contents
- HIVE: data connections, databases, resource queues, and script contents
- SPARK: data connections, databases, and script contents
- SHELL: host connections, parameters, interactive parameters, and script contents
- RDS: data connections, databases, and script contents
- PRESTO: data connections, modes, and script contents
- PYTHON: host connections, parameters, interactive parameters, and script content
- FLINK: script content
The procedure is as follows:
- In the script directory list, double-click a script that you want to develop. The script development page is displayed.
- On the right of the page, click the Versions tab and view the version submission records. Select the version to be rolled back and click Roll Back. If the content in the development state is not submitted, the content will be overwritten after the rollback. In this case, you must submit the rollback version again to make it take effect. By default, the latest submitted version is used for scheduling.Figure 2 Rolling back a version
Version Comparison
You can compare the script contents of two different versions. If you select only one version, the system compares the script content of the selected version with that in the development state. If you select two versions, the system compares the script contents of two different versions.
- On the right of the page, click the Versions tab and view the version submission records. Select the versions to be compared and click Compare Version. Figure 3 Comparing versions
- A new page is displayed, showing the script content of different versions on the left and right separately. The differences between the two versions have been marked. You can use the
and
buttons in the upper right corner to go to the previous or next change. Figure 4 Version comparison details
