Creating a Data Security Level (To Be Removed)
You can manage data security levels, including creating and deleting security levels and adjusting their ranking sequences.
Data security capabilities are provided by DataArts Security, and no longer by DataArts Catalog in regions where DataArts Security is available. Currently, the data security function in DataArts Catalog is available only to existing users.
DataArts Security is available in CN-Hong Kong, AP-Singapore, AP-Bangkok, AP-Jakarta, LA-Santiago, LA-Sao Paulo1, AF-Johannesburg, and TR-Istanbul.
You can create a data classification rule and data masking policy only after you have created a data security level.
None
Accessing the Data Security Levels Page
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate an instance and click Access. On the displayed page, locate a workspace and click DataArts Catalog.
- Choose from the left navigation bar. On the page displayed, you can create, delete, edit, move up, and move down data security levels as required.
- Creating a security level: Click Create in the upper left corner of the Data Security Levels page and enter the name and description.
- Deleting a security level: Select unnecessary security levels and click Delete in the upper left corner of the Security Levels page.
- Adjusting the ranking sequence of a security level: Click Up or Down to the right of a security level to adjust its sequence.
