Creating a Data Classification (To Be Removed)
You can create data classification rules.
Data security capabilities are provided by DataArts Security, and no longer by DataArts Catalog in regions where DataArts Security is available. Currently, the data security function in DataArts Catalog is available only to existing users.
DataArts Security is available in CN-Hong Kong, AP-Singapore, AP-Bangkok, AP-Jakarta, LA-Santiago, LA-Sao Paulo1, AF-Johannesburg, and TR-Istanbul.
You can create a data masking policy to mask data only after you have created a data classification rule.
A data security level has been created. For details, see Creating a Data Security Level (To Be Removed).
Creating a Data Classification Rule
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate an instance and click Access. On the displayed page, locate a workspace and click DataArts Catalog.
- Choose from the left navigation bar. On the Classification Rule tab page, click Create. On the page displayed, set the parameters to create a data classification rule. You can either create a rule by using a system template or custom template.Figure 1 Creating a data classification rule
Table 1 Parameters for creating a data classification rule Parameter
Classification Type
The category to which a rule belongs. You can either create a rule by using a system template or custom template.
Confidentiality
Classify the configured data into different levels. If the existing confidentiality does not meet the requirements, go to the confidentiality management page to set security levels. For details, see Creating a Data Security Level (To Be Removed).
Classification Template
This parameter is available when Classification Type is set to Built-in. You can select a system sensitive data identification template based on service requirements, for example, Time, Mobile number, and License plate number.
Classification Name
- If Classification Type is set to Built-in, a classification name is automatically generated based on the classification template selected.
- If Classification Type is set to Custom, you can customize a classification name. NOTE:
The name of a data classification rule must be unique.
Rule Recognition
This parameter is available when Classification Type is set to Custom. Regular expressions are supported.
Regular Expression
- Content recognition: You can customize a regular expression.
- Column name recognition: Both exact match and fuzzy match are supported. Multiple fields can be matched.
A description of the data classification rule to create.
Creating a Group
- Choose from the left navigation bar. On the Groups tab page, click Create.
In the Create Group dialog box, set the parameters and click OK.
Set the parameters by referring to Table 2 and select classification rules in the list.
The selected rules are displayed in the list on the right.
