Updated on 2025-09-09 GMT+08:00
Supported Data Sources (2.9.2.200)
CDM provides the following migration modes which support different data sources:
This section describes the data sources supported by CDM clusters of version 2.9.2.200. The supported data sources vary depending on the CDM cluster version.
Data Sources Supported by Table/File Migration
Table/File migration can migrate data in tables or files.
Table 1 describes the supported data sources.
Table 1 Supported data sources during table/file migration
Category
Source
Destination
Data warehouse
Data Warehouse Service (DWS)
  • Data warehouse: DWS, DLI, and MRS ClickHouse
  • Hadoop: MRS HDFS, MRS HBase, and MRS Hive
  • Object storage: Object Storage Service (OBS)
  • Relational database: RDS for MySQL, RDS for PostgreSQL, RDS for SQL Server, MySQL, PostgreSQL, Microsoft SQL Server, and Oracle
  • NoSQL: CloudTable
  • Search: Elasticsearch and Cloud Search Service (CSS)
The DWS physical machine management mode is not supported.
Data Lake Insight (DLI)
You must have the SELECT permission (for querying tables) on all fields of the DLI data source.
MRS ClickHouse
Data warehouse: MRS ClickHouse and DLI
  • Recommended MRS ClickHouse version: 21.3.4.X
  • MRS clusters whose Kerberos encryption type is aes256-sha2,aes128-sha2 are not supported, and only MRS clusters whose Kerberos encryption type is aes256-sha1,aes128-sha1 are supported.
Hadoop
MRS HDFS
  • Data warehouse: DWS and DLI
  • NoSQL: CloudTable
  • Supported by local storage. Only MRS Hive and MRS Hudi are supported in storage-compute decoupling scenarios.
  • Only MRS Hive is supported in Ranger scenarios.
  • Not supported if SSL is enabled for ZooKeeper
  • Recommended MRS HDFS versions:
    • 2.8.X
    • 3.1.X
  • Recommended MRS HBase versions:
    • 2.1.X
    • 1.3.X
  • MRS Hive and MRS Hudi 2.x versions are not supported. The following versions are recommended:
    • 1.2.X
    • 3.1.X
MRS HBase
MRS Hive
  • NoSQL: CloudTable
MRS Hudi
Data warehouse: DWS
FusionInsight HDFS
  • NoSQL: CloudTable
  • FusionInsight cannot serve as the destination.
  • Supported only by local storage and not in storage-compute decoupling scenarios
  • Not supported by Ranger
  • Recommended FusionInsight HDFS versions:
    • 2.8.X
    • 3.1.X
  • Recommended FusionInsight HBase versions:
    • 2.1.X
    • 1.3.X
  • Recommended FusionInsight Hive versions:
    • 1.2.X
    • 3.1.X
FusionInsight HBase
FusionInsight Hive
Apache HBase
  • NoSQL: CloudTable
  • Apache cannot serve as the destination.
  • Recommended Apache HBase versions:
    • 2.1.X
    • 1.3.X
  • Apache Hive 2.x versions are not supported. The following versions are recommended:
    • 1.2.X
    • 3.1.X
  • Recommended Apache HDFS versions:
    • 2.8.X
    • 3.1.X
Apache Hive
Apache HDFS
Object storage
  • NoSQL: CloudTable
  • Object Storage Migration Service (OMS) is recommended for migration between object storage services.
  • Binary files cannot be imported to a database or NoSQL.
File system
FTP
  • NoSQL: CloudTable
  • The file system cannot serve as the destination.
  • Only text files such as CSV files can be migrated from FTP or SFTP servers to search services. Binary files cannot.
  • obsutil is recommended for migrating data from HTTP servers to OBS. For details, see Introduction to obsutil.
SFTP
HTTP
Hadoop: MRS HDFS
Relational database
RDS for MySQL
  • Hadoop: MRS HDFS, MRS HBase, MRS Hive, and MRS Hudi
  • NoSQL: CloudTable
  • Relational database: RDS for MySQL, RDS for PostgreSQL, and RDS for SQL Server
  • Recommended Microsoft SQL Server version: 2005 or later
  • Greenplum, Kingbase, and GaussDB can be connected using the PostgreSQL connector. The supported source and destination are the same as those of the PostgreSQL data source.
RDS for SQL Server
  • NoSQL: CloudTable
RDS for PostgreSQL
MySQL
  • Object-based storage: Object Storage Service (OBS)
  • NoSQL: CloudTable
PostgreSQL
Oracle
  • NoSQL: CloudTable
SAP HANA
  • Data warehouse: DLI
  • Hadoop: MRS Hive
SAP HANA data sources have the following restrictions:
  • SAP HANA cannot serve as the destination.
  • Only the 2.00.050.00.1592305219 version is supported.
  • Only the Generic Edition is supported.
  • BW/4 FOR HANA is not supported.
  • Only database names, table names, and column names consisting of English letters are supported. Special characters such as spaces and symbols are not allowed.
  • The following data types are supported: date, digit, Boolean, and character (except SHORTTEXT). Other data types such as binary are not supported.
  • During migration, tables cannot be automatically created at the destination.
Database sharding
  • Hadoop: MRS HBase and MRS Hive
Database shards cannot serve as the destination.
A shard link connects to multiple backend data sources at the same time. The link can be used as the job source to migrate data from those data sources to other data sources.
NoSQL
Redis
NoSQL except CloudTable cannot serve as the destination.
Document Database Service (DDS)
MongoDB
CloudTable HBase
  • NoSQL: CloudTable
Cassandra
  • NoSQL: CloudTable
Message system
Data Ingestion Service (DIS)
Search: Cloud Search Service (CSS)
The message system cannot serve as the destination.
Apache Kafka
DMS Kafka
MRS Kafka
  • NoSQL: CloudTable
  • MRS Kafka cannot serve as the destination.
Search
Elasticsearch
  • NoSQL: CloudTable
Only the non-security mode is supported.
You are advised to use Logstash to import data to CSS. For details, see Using Logstash to Import Data to Elasticsearch
In the preceding table, the non-cloud data sources, such as MySQL, include on-premises MySQL, MySQL built on ECSs, or MySQL on the third-party cloud.
Supported Data Sources in Entire DB Migration
Entire DB migration is used when an on-premises data center or a database created on an ECS needs to be synchronized to a database service or big data service on the cloud. It is suitable for offline database migration but not online real-time migration.
Table 2 lists the data sources supporting entire DB migration using CDM.
Table 2 Supported data sources in entire DB migration
Category
Data Source
Read
Write
Data warehouse
Supported
Supported
Hadoop
(available only for local storage, and not for storage-compute decoupling, Ranger, or ZooKeeper for which SSL is enabled)
MRS HBase
Supported
Supported
Entire DB migration only to MRS HBase
Recommended versions:
  • 2.1.X
  • 1.3.X
MRS Hive
Supported
Supported
Entire DB migration only to a relational database
  • 1.2.X
  • 3.1.X
FusionInsight HBase
Supported
Not supported
  • 2.1.X
  • 1.3.X
FusionInsight Hive
Supported
Not supported
  • 1.2.X
  • 3.1.X
Apache HBase
Supported
Not supported
  • 2.1.X
  • 1.3.X
Apache Hive
Supported
Not supported
  • 1.2.X
  • 3.1.X
Relational database
RDS for MySQL
Supported
Supported
Migration from OLTP to OLTP is not supported. In this scenario, you are advised to use the Data Replication Service (DRS).
RDS for PostgreSQL
Supported
Supported
RDS for SQL Server
Supported
Supported
MySQL
Supported
Not supported
PostgreSQL
Supported
Not supported
Supported
Not supported
Oracle
Supported
Not supported
SAP HANA
Supported
Not supported
Dameng database
Supported
Not supported
Only to DWS and Hive
NoSQL
Redis
Supported
Supported
Supported
Supported
Only migration between DDS and MRS is supported.
CloudTable Service (CloudTable)
Supported
Supported
