Updated on 2025-07-25 GMT+08:00
Managing Asset Tags
Tags can be defined and associated with technical assets for better asset management. For example, you can tag a table as the SDI source data layer or DWI data integration layer.
Tags are keywords used to identify the business meanings of technical assets. They help you classify and describe technical assets for easy search.
Tags and Classifications
Tags are highly related keywords that help you classify and describe assets for easy retrieval.
Classification is the process of categorizing assets by category, level, or nature. Classification is top-down. Assets are classified according to certain standards.
The table below lists the differences between tags and classifications.
Table 1 Differences between tags and classifications
Item
Category
Tag
Exclusiveness
Yes
None
Relationship
Dependent
Relevant (associated)
Creation
Pre-event planning
Any time
Cost
High
Low
Source
For details, see Creating a Data Classification (To Be Removed).
For details, see Managing Asset Tags.
Managing a Tag
  1. On the DataArts Studio console, locate a workspace and click DataArts Catalog.
  1. Choose Data Map > Tag Management from the left navigation bar.
  2. Click Create to create a tag.
    • Tag Name: Tag names can include only letters, numbers, and underscores (_). They cannot start with underscores (_) or exceed 100 characters.
    • Description: Up to 255 characters are allowed.
  3. Select a tag and click Delete to delete the tag.
  4. Click Edit to modify the description of a tag.
Identifying Technical Assets: Adding Tags
  1. Choose Data Map > Data Catalog and click the Technical Assets tab.
  2. Enter a keyword in the search box, and click the search icon. The search results are listed below the search box.
  1. Select the technical asset that you want to add a tag to and click Add Identifier in the upper right corner. In the Add Identifier dialog box, select Tags for Type.
    Figure 1 Adding an identifier
  2. Set the parameters and click OK.
    You can add a new tag or select an existing tag. Existing tags are created by following instructions in Managing a Tag.
