Updated on 2025-07-25 GMT+08:00
Creating a Business Scenario
Business scenarios are used to monitor business metrics. This section describes how to create a business scenario.
- On the DataArts Studio console, locate a workspace and click DataArts Quality.
- Create a metric.
- In the navigation pane on the left, choose Metrics.
- On the Metrics page, click Create.
- Click Trial Run to check whether the metric runs properly.
- Click OK.
- Create a rule.
- Create a scenario.
- In the navigation pane on the left, choose Scenarios.
- On the Scenarios page, click Create. On the displayed Create Scenario page shown in the following figure, set the required parameters.
- Click Next and set the parameters for the rule group.
- Click Next and set subscription parameters.
- Click Next and set scheduling parameters.
- Click Submit.
- In the scenario list, locate the created scenario and click Run in the Operation column.
- Click the refresh button in the upper right corner. The Running Status of the scenario is Succeeded.
- Click the running result to view details.
Parent topic: Tutorials
