Viewing Job Instances
GUI Description
The following figure shows the areas and buttons on the O&M page.
| No. | Area | Description |
| 1 | Navigation bar | Contains the storage directory of data quality rules. You can store rules in different directories tailored to service requirements. The number next to each directory indicates the number of rule instances stored in the directory. |
| 2 | List of rule instances | Displays the instance name, type, running status, and running result. |
| 3 | Management area | Provides buttons for exporting, deleting, and stopping selected instances. |
| 4 | Search area |
| 5 | Concurrent SQL statements | Click SQL. In the displayed Configure Concurrent SQL Statements for a Connection dialog box, set the number of concurrent SQL statements. Enter a value from 10 to 1,000. Click OK. NOTE: If the maximum number of SQL statements that can be executed for a data connection has been reached, the excess SQL statements will be queued. |
| Parameter | Description |
| Instance Name | Consists of a rule name and a number. The larger the number is, the later the instance is created. |
| Type | Displays the job type. The value can be Quality Job or Comparison Job. |
| Running Status | Displays the running status of an instance, such as Successfully, Failed, Running, and Alarming. In the right pane, you can view the detailed run logs of the rule instances.
| Notification | Displays the notification status of an instance, such as Successfully, Failed, and Not triggered. |
| Operator | Displays the operator of the instance. |
| Created | Displays the time when the instance was created. |
| Start Time | Displays the time when the instance starts to run. The start time can be sorted in ascending or descending order. |
| Running Duration | Displays the running duration of the instance. |
| End Time | Displays the time when the instance execution is complete. The end time can be sorted in ascending or descending order. |
| Handled By | Displays the handler of the instance. |
| Rerun | Allows you to run a rule instance again. |
| Details | Displays the execution results and logs of job instances.
| More > Rectify | Allows you to perform further processing on a rule instance. For example, you can Provide defects directly, Close defects, or Specify a user to rectify fault. The above operations can be performed only when you are the handler of the instance. |
| More > Refresh Job Status | Refresh the job status. |
More Operations
- Exporting job instances
Select job instances and click Export. In the displayed Export Instance Running Results dialog box, click Export. On the Export Records tab page, you can check whether the selected instances are successfully exported. You can also download the job instances that have been exported.
- Deleting job instances
- Stopping job instances
- Rerunning a job instance
Locate a job instance and click Rerun in the Operation column.
