Viewing a Scenario Instance
You can manage all scenarios, view metric running statuses, query run logs, and handle issues on the O&M Management page.
GUI Description
The following figure shows the areas and buttons on the O&M page.
No. |
Area |
Description |
1 |
Menu bar |
The menu bar on the O&M Management page includes Scenario Instances and Subscriptions.
2 |
Navigation bar |
Contains the directories that store scenario instances. You can store scenarios in different directories. The number next to each directory indicates the number of scenarios stored in that directory. |
3 |
List of scenario instances |
Displays the instance name, running status, and running result. |
4 |
Search area |
Parameter |
Description |
Running Status |
Displays the running status of a scenario instance.
Running Result |
Displays whether the scenario instance is running properly.
Rerun |
Allows you to run the scenario instance again. |
View Log |
Allows you to view the running details of the scenario instance. |
More > Resolve Issue |
Allows you to perform further processing on the scenario instance. You can Provide handling suggestions, Close the issue, or Transfer to others. The above operations can be performed only when you are the handler of the instance. |
More > View Processing Log |
Allows you to view historical processing records. |
