Updated on 2025-09-09 GMT+08:00
Creating a Metric
You can manage all business metrics, including the metric sources and definitions. Business metrics are stored in directories.
Metrics in DataArts Quality are independent of business metrics and technical metrics in DataArts Architecture.
You have created a home directory. To create a home directory, log in to the DataArts Studio console, click Access under a specific instance, choose More > DataArts Quality on the Workspaces tab page, choose Metric Monitoring > Metric Management from the left navigation bar on the page displayed, and create a directory. Before creating a metric for a data connection, select a directory to store the metric. For details, see Figure 1.
Figure 1 Directory that stores the metric to create
Table 1 Buttons in the navigation bar
No.
Create Directory
2
Refresh Directory
3
Right-click All to create, rename, or delete a directory.
Creating a Metric
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Quality.
  1. Choose Metric Monitoring > Metrics from the left navigation bar.
  2. Click Create. In the dialog box displayed, set the parameters based on Table 2.
    Table 2 Metric parameters
    Metric Name
    The name of a metric, which contains 1 to 64 characters and consists of only letters, numbers, and underscores (_).
    Data Connection
    Select a created data connection from the drop-down list box.
    • Currently, only DWS, MRS Hive, DLI, MRS ClickHouse, and Doris are supported.
    • Metrics are closely connected based on data connections. Therefore, you must establish data connections in the metadata management module before creating metrics.
    Database/Queue
    Select the database where the metric runs.
    If DLI is selected as the data connection, a running queue is required.
    Information to better identify a metric. It cannot exceed 4096 characters.
    Directory
    Directory for storing metrics. You can select a created directory. Figure 1 shows the directory.
    Metric Type
    Custom is supported.
    You can customize an SQL statement to define the metric source.
