Updated on 2025-04-09 GMT+08:00
Overview
The metric monitoring function of DataArts Quality will be unavailable soon. You are advised to use DataArts Architecture in the future, which provides comprehensive metric design and management capabilities.
The Metric Monitoring module manages business metrics.
To monitor a business metric, customize a SQL metric, define a rule based on the logical expression of the metric, and create and run a business scenario. Based on the running result of the business scenario, you can determine whether the business metric meets the quality rule. The running result of the business scenario may be any of the following:
  • Normal: The instance stops normally and the running result meets the expectation.
  • Alarming: The instance stops normally, but the running result does not meet the expectation.
  • Abnormal: The instance stops unexpectedly.
  • --: The instance is running, but no running result is displayed.
The following table describes modules under Quality Monitoring.
Function
Dashboard
Default homepage. This page contains the following parts:
  • Quick Start that demonstrates how you can use metric monitoring
  • Running and alarm statuses for the business scenario instance over the last seven days
  • Alarms, scenarios, and metrics in different time periods
Metrics
You can create metrics on this page.
Rules
You can create rules based on the logical expressions of metrics on this page.
A business scenario can be considered as a business metric quality job. On this page, you can schedule and run a created rule group.
O&M
You can view the running statuses of business scenario instances and handle O&M issues. The Subscriptions page displays the running statuses of all the tasks you have subscribed to.
