Restarting a CDM Cluster
After modifying some configurations (for example, disabling user isolation), you must restart the cluster to make the modification take effect.
If you restart a CDM cluster process or VM, jobs that are running will fail, and no jobs can be scheduled during the restart. Exercise caution when performing this operation.
You have created a CDM cluster.
Restarting a cluster
- Log in to the CDM console and choose Cluster Management in the left navigation pane.
Another method: Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console. On the DataArts Studio console, locate a workspace and click DataArts Migration to access the CDM console.
Figure 1 Cluster list
The Source column is displayed only when you access the DataArts Migration page from the DataArts Studio console.
- Locate the row that contains the target cluster, click More in the Operation column, and select Restart from the drop-down list.Figure 2 Restarting a cluster
- Select Restart CDM service process or VM restart and click OK.
- Restart CDM service process: Only the CDM service process is restarted. The cluster VM will not be restarted.
- VM restart: The service process will be interrupted and VMs in the cluster will be restarted.
