Updated on 2025-09-09 GMT+08:00
MRS Kafka
Functions
The MRS Kafka node is used to query the number of messages that are not consumed by a topic.
Kafka is an open-source, distributed, partitioned, and replicated commit log service. Kafka is publish-subscribe messaging, rethought as a distributed commit log. It features message endurance, high throughput, distributed methods, multi-client support, and real time. It applies to both online and offline message consumption, such as regular message collection, website activeness tracking, aggregation of statistical system operation data (monitoring data), and log collection. These scenarios engage large amounts of data collection for Internet services. As a message publishing and subscription system, Kafka allows high-speed data transmission between different subsystems of the FusionInsight platform.
Parameters
Table 1 and Table 2 describe the parameters of the MRS Kafka node.
Table 1 Parameters of MRS Kafka nodes
Mandatory
Data Connection
Yes
Select the MRS Kafka connection created in the management center.
Topic Name
Yes
Select a topic that has been created in MRS Kafka. The SDK or command line can be used to create a topic. For details, see Using Kafka from Scratch.
Node Name
Yes
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Table 2 Advanced parameters
Mandatory
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
Yes
Whether to re-execute a node if it fails to be executed. Possible values:
  • Yes: The node will be re-executed, and the following parameters must be configured:
    • Retry upon Timeout
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node will not be re-executed. This is the default setting.
    If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
    If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
    Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
Policy for Handling Subsequent Nodes If the Current Node Fails
Yes
Operation that will be performed if the node fails to be executed. Possible values:
  • Suspend execution plans of the subsequent nodes: stops running subsequent nodes. The job instance status is Failed.
  • End the current job execution plan: stops running the current job. The job instance status is Failed.
  • Go to the next node: ignores the execution failure of the current node. The job instance status is Failure ignored.
  • Suspend the current job execution plan: If the current job instance is in abnormal state, the subsequent nodes of this node and the subsequent job instances that depend on the current job are in waiting state.
Enable Dry Run
No
If you select this option, the node will not be executed, and a success message will be returned.
Task Groups
No
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning.
