(Optional) Changing the Job Log Storage Path
By default, job logs and DLI dirty data are stored in an OBS bucket named dlf-log-{project ID}. You can customize a storage path for logs and one for DLI dirty data. You can also configure an OBS bucket globally based on the workspace.
Notes and Constraints
- This function depends on the OBS service.
- The OBS path is only supported for OBS buckets and not for parallel file systems.
- DAYU Administrator or Tenant Administrator
- DAYU User, which is the administrator of the current workspace
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the Workspaces page, locate a workspace and click Edit in the Operation column. Figure 1 Workspace Information
- In the Workspace Information dialog box, click Select OBS Path next to Job Log Path and Dirty Data Path and select a path. Figure 2 Changing the job log path and DLI dirty data path
- Click OK.
