Developing a DWS SQL Job
This section describes how to use the DWS SQL node to develop a job in DataArts Factory.
This tutorial describes how to develop a DWS job to collect the sales volume of a store on the previous day.
Preparing the Environment
Creating a DWS Data Connection
Before developing a DWS SQL job, you must create a data connection to DWS on the Manage Data Connections page of Management Center. The data connection name is dws_link. For how to create a DWS connections, see DWS Connection Parameters.
The key parameters are as follows:
- Cluster Name: Select the DWS cluster you have created when preparing the environment.
- Agent: Select the CDM cluster you have created when preparing the environment.
Creating a Database
Create a gaussdb database by following the instructions in Creating a Database.
Creating Data Tables
Create tables trade_log and trade_report in the gaussdb database. The following is an example script for creating the tables:
create schema store_sales;
set current_schema= store_sales;
drop table if exists trade_log;
CREATE TABLE trade_log
sn VARCHAR(16),
trade_time DATE,
trade_count INTEGER(8)
drop table if exists trade_report;
CREATE TABLE trade_report
rq DATE,
trade_total INTEGER(8)
Developing a DWS SQL Script
Choose Development > Develop Script and create a DWS SQL script named dws_sql. Enter an SQL statement in the editor to collect the sales amount of the previous day.
Key notes:
- The script development area in Figure 1 is a temporary debugging area. After you close the script tab, the development area will be cleared. You can click Submit to save and submit a script version.
- Connection: Select the data connection created in Creating a DWS Data Connection.
After developing the DWS SQL script, create a job for periodically executing the DWS SQL script.
- Create a batch job named job_dws_sql.
- Go to the job development page, drag the DWS SQL node to the canvas, and click the node to configure its properties.
Figure 2 Configuring properties for the DWS SQL node
Key properties:
- SQL script: Associate with the dws_sql script developed in Developing a DWS SQL Script.
- Data Connection: Select the data connection configured in the dws_sql script. The data connection can be changed.
- Database: Select the database configured in the dws_sql script. The database can be changed.
- Script Parameter: Obtain the value of yesterday using the following EL expression:
#{Job.getYesterday("yyyy-MM-dd")} - Node Name: The name of the dws_sql script is displayed by default. The name can be changed.
- After configuring the job, click
to test it. - If the test is successful, click the blank area on the canvas and then the Scheduling Setup tab on the right. On the displayed page, configure the scheduling policy.
Figure 3 Configuring the scheduling policy
Parameter descriptions:
From Aug 6 to Aug 31 in 2021, the job was executed once at 02:00 every day.
- Click Submit and then Execute. The job will be executed automatically every day.
