Overview
Choose Monitoring > Overview. On the Overview page, you can view the statistics of job instances in charts. Currently, you can view the following statistics:
- Status
- You can filter out your or all job instances by selecting My Instances or All, and filter out job instances of the current day by selecting Today.
- You can filter out your or all job instances by selecting My Instances or All, and filter out job instances of the current day by selecting Yesterday.
- You can filter out your or all job instances by selecting My Instances or All, and filter out job instances of the current day by selecting Two days ago.
- You can filter out your or all job instances by selecting My Instances or All, and filter out job instances of the current day by selecting Last 7 days.
- You can click a status to go to the Monitor Instance page and view details about all jobs in the status.
- The statistics include the monitoring data of the instances of real-time jobs. When you click a status, you will not be redirected to the Monitor Instance page of real-time jobs. Instead, you can only view the details of the instances of batch jobs.
- By default, the system displays all job instances of the current day.
- You can view the total number of instances that meet the filter criteria, the total number of instances that were successfully executed, and the percentage of such instances.
Figure 1 Status
- Completed Tasks
Successfully executed instances of the current day are collected once an hour. A task is a job node.
- You can specify a date and view the number of all job nodes successfully executed on the previous day, on the selected day, and over the last seven days on average.
- You can specify a date and view the number of different types of job nodes successfully executed on the previous day, on the selected day, and over the last seven days on average.
- Job Operations
You can view job operation statistics in a specified period, including the number of started, stopped, and changed jobs.
Started Jobs: the number of times that jobs have been started in the current period
Stopped Jobs: the number of times that jobs have been stopped in the current period
Job Changes: the number of times that versions have been submitted for jobs in the current period
You can view data of one year at most.
You can query data by owner.
You can search for a job exactly by its name.
- Tasks
Number of tasks (operators in jobs) started in five minutes. Data of 30 days is available.
- You can filter the operators started on each day within 30 days.
- You can view the curve of the number of all operators that have been started.
- You can view the curve of the number of different types of operators that have been started.
- Running DLI Jobs/Queue CU Usage
You can filter the number of running DLI jobs and the CU usage of a specified queue.
- You can view data of one day by default, and view data of seven days at most.
- You can only view data of non-default queues. You can click the name of a queue to pin the queue to top.
- Number of Jobs and Number of Tasks Scheduled Daily
This area displays the trend of the total number of jobs in a long period and the number of tasks scheduled each day. A task indicates an operator in a job.
Number of jobs: total number of batch and real-time processing jobs
Number of tasks scheduled daily: number of tasks scheduled everyday, including both real-time and offline tasks. The number is calculated based on the nodes that are successfully scheduled.
- By default, the system displays the number of jobs and the number of tasks scheduled each day in one month. You can filter data by time range.
- Task Type Distribution
You can view the number of job nodes of different types.
The system collects statistics on the number of nodes in all submitted jobs, including real-time and batch processing jobs.
- Top 100 in Instance Running Time
- You can filter out the top 100 instances of yours or all users with the longest running duration by time and owner.
- You can click a job name to go to the Monitor Instance page and view the job running details.
- By default, the system displays top 100 job instances in one day.
- Top 100 in Instance Failed to Run
- You can filter out the top 100 instances of yours or all users with the most failures by time and owner.
- You can click a job name to go to the Monitor Instance page, view the logs of the failed job instances, and analyze the causes.
- By default, the system displays batch job instances in one day.
- End of scheduling in the next week
You can view the jobs that are expected to be completed in the following week, including their names, owners, and end time.
- Jobs that are expected to be completed in two days or less are displayed in red.
- Jobs that are expected to be completed in three to five days are displayed in orange.
- Jobs that are expected to be completed in six to seven days are displayed in black.
