Notebook
Functions
The Notebook node is used to execute a Notebook job predefined in DLI.
This function depends on OBS.
Parameters
Table 1 and Table 2 describe the parameters of the Notebook node.
| Parameter | Mandatory | Description |
| Node Name | Yes | Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Spark Job Name | Yes | Name of the DLI Spark job. The name must contain 1 to 64 characters, including only letters, numbers, and underscores (_). The default value is the same as the node name. |
| Data Lake Insight Queue | Yes | Select a queue from the drop-down list box.
| Job Type | No | You can set this parameter as needed after selecting a DLI queue. Type of the Spark image used by the job. The following options are available:
| Spark Versions | Yes | This parameter is mandatory when a DLI queue is selected. Select a Spark version. |
| Job Running Resources | No | Select the running resource specifications of the job.
| Input directory | Yes | Select a path in the OBS bucket for running the notebook file. The absolute path of the input directory can contain a maximum of 1,024 characters. |
| Input Notebook File | Yes | Select the notebook file in the OBS input directory. The file is in .ipynb format. The absolute path can contain a maximum of 2,048 characters. |
| Notebook File Output Directory | Yes | Select a path in the OBS bucket for storing the running result of the notebook file. The absolute path of the output directory can contain a maximum of 1,024 characters. |
| Output Notebook File Name | Yes | Enter the name of the output notebook file. The name can contain a maximum of 256 characters. The file is in .ipynb format. |
| Input Notebook Job Parameters | No | Configure the parameters for running the notebook job. |
| Spark program resource package | No | Enter a parameter in the format of key=value. Press Enter to separate multiple key-value pairs. For details about the parameters, see Spark Configuration. These parameters can be replaced by global variables. For example, if you create a global variable custom_class on the Global Configuration > Global Variables page, you can use "spark.sql.catalog"={{custom_class}} to replace a parameter with this variable after the job is submitted.
         The JVM garbage collection algorithm cannot be customized for Spark jobs. |
| Node Status Polling Interval (s) | Yes | How often the system check completeness of the node. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed. Possible values:
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select this option, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
