SMN
Functions
The SMN node is used to send notifications to users.
Parameters
Table 1 and Table 2 describe the parameters of the SMN node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
Topic Name |
Yes |
Name of the topic. The topic has been created in SMN. |
Message Title |
No |
Title of the message. The title cannot exceed 512 characters. |
Message Type |
Yes |
Format of the message.
Message Content |
Yes |
Message content to be provided. The requirements for entering different types of messages are as follows:
To learn more about SMN configuration, see Publishing a Message in the Simple Message Notification User Guide. |
Parameter |
Mandatory |
Description |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
Retry upon Failure |
Yes |
Whether to re-execute a node if it fails to be executed. Possible values:
Policy for Handling Subsequent Nodes If the Current Node Fails |
Yes |
Operation that will be performed if the node fails to be executed. Possible values:
Enable Dry Run |
No |
If you select this option, the node will not be executed, and a success message will be returned. |
Task Groups |
No |
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
